-   -   10/12 Roof Pitch (http://www.diychatroom.com/f9/10-12-roof-pitch-68152/)
jonathan03 04-02-2010 10:53 AM
10/12 Roof Pitch
Is a 10/12 Roof pitch walkable? I want to put on shingles in a small area of the roof but I'm wondering if I can just support myself by sitting down or if I need a ladder resting against a 2x4 nailed to the roof. What is generally the best way to be supported on a roof like this? I'm comfortable laying shingles, just not sure if this pitch is too steep to walk on or other means. Is a cherry picker needed?
oberkc 04-02-2010 01:22 PM
Barely. Mine is 10/12. I can walk in valleys and on peaks, but do not dare attempting to walk on other areas for fear of sliding off.
I would not attempt to install a roof without additional support. I believe the common way of dealing with this is roof jacks.
jlhaslip 04-02-2010 03:22 PM
roof jacks, planks, and a fall protection/positioning harness/rope system.
KyleB 04-02-2010 11:06 PM
10/12 is pushing it. I wouldn't attempt to roof that without roof jacks and a harness.
Was a roofer for 6 years ;)
AaronB 04-03-2010 12:40 AM
Too steep to safely walk. Def use some form of fall protection and support while working.
tpolk 04-03-2010 10:24 AM
if you are going to fall wear proper rope and harness with deceleration attatchment
