Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 12-18-2006, 06:32 PM   #1
1/8" gap between OSB sheeting to allow for expansion?
I know that when sub flooring with OSB that it is sugested that you leave an expansion gap of 1/8 inch. Do any of you do this for sub roofing. I would guess not ....but would like to know the practice.
pmaru77 is offline   Reply With Quote
Old 12-18-2006, 06:37 PM   #2
renovations
If you're using "h-clips" then this will do that for you, if not, I put a 2' nail between the sheets for expansion. Actually it has more to do with contraction of the rafter/joist, the OSB is pretty stable.
Bonus is offline   Reply With Quote
Old 12-18-2006, 06:43 PM   #3
I just did a 9x12 shed and all my seams are on rafters...no gap. So the contraction of the joist brings the OSB onto a collision course? So say the rafter shrinks to 1 7/16 from 1 9/16....so a 1/8 inch collision. But not until many years?
Old 12-18-2006, 11:33 PM   #4
Log-Style Home Contractor
North Country's Avatar
The reason for this 1/8" gap is to take into account the expansive properties of OSB. LEave a sheet out in the rain and you'll see what I mean.
North Country is offline   Reply With Quote
Old 12-19-2006, 12:21 AM   #5
I had built a roof over our front porch using OSB and did not leave an expansion gap...what a mistake! Over time it was easy to see the bowing that occurred. We had the house reroofed this year by a roofing company with me replacing the the porch roof sheathing.
I wanted to do the work for a couple of reasons...the main one being having access to run some telephone and computer cables to other rooms in the house and to use 3/4 inch ply instead of 1/2 inch the roofing company wanted to use.
An expansion gap of 1/8 inch was used and the areas I felt were too tight I ran the skillsaw along the seam with the blade set at 3/4 inch. The roofing company and building inspector were both pleased with the gaping between the sheets.
caseywa is offline   Reply With Quote
Old 01-31-2007, 12:46 PM   #6
Commercial Roofing
AaronB's Avatar
Use the clips.
Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
properly nailing down 1/2" osb sheeting over lath FISH275 Roofing 2 04-08-2007 01:49 PM
