Would A Tile Floor In A Seasonal Cottage Crack If Not Heated - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 08-28-2012, 10:23 PM   #1
would a tile floor in a seasonal cottage crack if not heated
If I installed ceramic tile in a cottage in northern Michigan that I only turn the heat on when I visit in winter when I leave I drain water and turn heat off would it crack from the tempeture changes it can be as low as 0 degrees farenheit as warm as 70 degrees when I am there
Toddhvac is offline   Reply With Quote
Old 08-28-2012, 10:54 PM   #2
Rewards Points: 940
I don't think so. Just keep the installation dry and you are ok. You can store tile outdoors and it will be ok, the same with mortar. But you can't store wet mortar outdoors.
Have you ever shown up at the place and found all your dinnerware and glassware broken because of the cold?
cleveman is offline   Reply With Quote
Old 08-28-2012, 10:58 PM   #3
Rewards Points: 13,300
We had summer homes all over NH with tiles floors and I've never seen one crack from temperture change.
"Temporary" tile job? M3 Pete Tiling, ceramics, marble 5 02-27-2012 04:01 PM
Tile over Tile ?? Piney Flooring 17 02-06-2012 10:59 PM
heated tile flooring in basement Dave Arthur Tiling, ceramics, marble 1 01-21-2012 12:07 PM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 04:31 PM
Tile and laminate, or get rid of tile? kfoster Flooring 10 03-17-2006 03:14 PM
