Will Thinset Stick To Vinyl Window? - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 11-28-2011, 03:04 PM   #1
Rewards Points: 170
Will Thinset stick to Vinyl Window?
I'm remodeling my bathroom and I want to tile around a small window in the upper part of the shower wall. I want to overlap the hardibacker and some of the vinyl window border.
Will Thinset and Tile stick to vinyl if I rough it up with sandpaper?
HandyFrank is offline   Reply With Quote
Old 11-28-2011, 07:30 PM   #2
Tileguy
JazMan's Avatar
Rewards Points: 422
It may work for your purpose, but I think it's not a smart thing to do. That area is subject to flex, vibration, temperature swings and condensation. What's the point to cover it? Why not tile to within 1/8" of the window and then caulk it?
Windows in a wet area are always a problem eventually. How are you gonna waterproof that area? Remember neither tile or grout will make it waterproof.
Jaz
Old 11-29-2011, 12:12 AM   #3
Rewards Points: 170
Thanks for the info. The window is already set in place and is a little too deep and can't be shifted in any more since it lines up with the siding and aluminum wrap on the outside. The Hardibacker lifts the wall tile too far off so we were considering having it overhang the vinyl and then caulk the inner edge where the tile finishes and the vinyl continues on.
The window is a crank type and is set up high so it gets the occasional spray but is not a direct shot of water since the bottom is up at over 5 feet.
Don't have a ton of options since the window is set in, but not enough to fit something grand within.
More feedback is welcome
Getting Vinyl Bathroom Coving To Stick!!! rahtreelimbs Flooring 3 04-20-2009 07:23 PM
underlayment for stick on tiles or vinyl novice40 Flooring 7 09-03-2008 04:49 PM
Vinyl window stuck in wood frame rlcarter Remodeling 7 09-26-2007 05:29 PM
Window Frame Materials - Vinyl vs Aluminum vs Fiberglass chrison600 Building & Construction 2 10-09-2005 11:13 AM
locate a vendor for vinyl window pane trim bjr23 Remodeling 1 02-13-2005 11:59 PM
