Why Can't You Use Sanded CAULK For ALL Tile Joints In Your Shower? - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 09-30-2012, 11:12 AM   #1
Why can't you use sanded CAULK for ALL tile joints in your shower?
Also, does sanded GROUT allow water to pass through it and under the tile?
All my joints are over 1/8 inch.
And one more question...I have a small gap in my shower floor that needs patching. Should I score it and use sanded GROUT?
l3randonf is offline   Reply With Quote
Old 09-30-2012, 11:50 AM   #2
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,074
Why can't you use sanded grout for all the seams in your shower?
Money. Time. Grout is easier to clean and maintain. Caulking needs to be replaced periodically. Grout doesn't unless something was not done right.
Yes. Grout is not water proof. Sealed grout is not waterproof. A shower should be 100% waterproof before the first tile goes up.
Probably. Got a pic? Keep in mind "small" issues (like loose tiles) on the floor or lower area of a shower can be symptoms of a bigger problem or that something was not done right. Keep an eye on it.
Old 09-30-2012, 12:16 PM   #3
What do you mean it should be water proof before the first tile goes up? Under my tile is thin set..and then under that is the shower pan...and then under that is sand...and then under that is concrete foundation. Is this wrong? Is this waterproof?
I don't understand how it is acceptable to have water pass through your grout and then subsequently, under the tile. Can you explain?
Also, why does the sanded caulk state that it is not for areas with constant water exposure?
Thanks for your time.
Old 09-30-2012, 07:50 PM   #4
Stuck in the 70's
If you read this link, you will see that there should be a showerpan liner in there. This ensures all of the water goes down the drain and not soak into the subfloor underneath.
http://www.ontariotile.com/preslope.html
I wrote this post a while back. Maybe it will help explain.
Waterproofing tiled shower walls.
Don't know. Possibly means being wet 24/7 rather than daily shower type situation.
Old 09-30-2012, 09:30 PM   #5
Ole Wood Worker
BigJim's Avatar
Rewards Points: 118
Are you saying sanded caulk or did you mean sanded grout?
New members: Please consider adding your location to your profile.
He is no fool who gives what he cannot keep, to gain what he cannot lose.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Crack in old shower tile Jeff DIY Flooring 21 01-15-2012 03:11 PM
Problems re-grouting shower tile Bartman72 General DIY Discussions 5 10-22-2011 02:37 PM
Filling/covering control joints while laying tile on concrete Marita Tiling, ceramics, marble 0 09-19-2010 02:46 PM
water leak on tile shower floor redskins Plumbing 1 07-18-2009 06:58 AM
what to use on joints with tile backer fabian Kitchen & Bath Remodeling 3 02-09-2009 06:49 PM
