Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Flooring > Tiling, ceramics, marble
Old 11-07-2009, 02:28 AM   #1
white spots on gea verda tile around salt water pool
just install a new salt water pool a few weeks ago. now the tile around the pool area is getting white spots. any suggestion to how to stop this or is this going to be and on going problem. can you suggest a cleaner to help remove them or maybe something else that may stop it. thanks for any information. also this pool is an indoor pool
mayo2965 is offline   Reply With Quote
Old 11-07-2009, 05:46 AM   #2
Remodeling Contractor
most likely this is efflorescence. The grout in the tiles had too much water content when laid. you can get cleaners for this at mason supply houses.
Old 11-08-2009, 05:11 PM   #3
Are the spots on the tile or the grout, what type of tile, glazed or is this stone?
Bet the salt water has a play in this.
R&D Tile is offline   Reply With Quote
Old 11-10-2009, 12:01 PM   #4
It is a porcelian tile.we install it in a carport that we made in to a indoor pool.
Old 11-10-2009, 06:01 PM   #5
Tileguy
mayo?
Listen up!
I doubt very much it is efflorescence.
Always follow the manufacturer’s recommendations as the first source of information for tile or stone installations and always refer to the TCNA Handbook For Installation of Ceramic Tile for the proper tile installation guidelines and standards.
Old 11-10-2009, 07:06 PM   #6
White spots on the tile. The tile is porcelian and glazed
Old 11-11-2009, 04:03 PM   #7
I bet it's dry salt from the water, does it wipe up?
Old 11-11-2009, 07:59 PM   #8
no they do not wipe up. and i just found out from the pool guy there is no salt in the pool yet. it will be a few more weeks. he said he has to shock it first before adding everything else. the only chemical in the pool is muratic acid
Old 11-12-2009, 10:20 PM   #9
Tileguy
It will be a few more weeks.
......and how is the tile and grout supposed to survive being soaked 24/7 in Muriatic acid. How much Muriatic acid? What's the ratio?
Old 11-13-2009, 06:37 AM   #10
take a picture then tape down 2'0x2'0 piece of plastic for a wk,,, IF there's wtr on top, its the pool,,, underneath, if they're enlarg'd OR there's more of 'em, its not vapor barrier under the slab ? ? ?
itsreallyconc is offline   Reply With Quote
More On This Topic
How to Identify White Spotted Filefish
How to Identify White Spotted Filefish by eHow Sports & Fitness Editor
Which fish did you see on your dive? Learn tips for white spotted filefish identification in this free scuba diving video of Caribbean fish from a staff member of the New England aquarium. Read More »
To avoid white spots on the nails, first determine what has caused the white spots, whether it be a small trauma or injury to the nail bed, a deficiency in vitamins or an underlying infection called leukonychia. Determine the cause of white spots on the... Read More »
How to Seal Tile
How to Seal Tile by eHow.com
Most tiles used in homes are glazed, and the glazing process creates a seal. But if you use porous materials, such as terra cotta, marble or slate, you will need to seal the tile to keep the surface looking good and to prevent stains on that surface you... Read More »
About DIY Plumbing
About DIY Plumbing by Shawn Kenny
Before tackling plumbing problems at home, make sure to get the proper tools and mindset for the job at hand. Avoid making huge mistakes when fixing plumbing issues without professional assistance with help from a plumber and HVAC tech in this free video... Read More »
[IMG] code is Off
Low hot water pressure crebive Plumbing 26 01-10-2010 12:54 PM
Wiring for swimming pool heater and salt system Scooby Electrical 1 06-08-2009 12:59 PM
Water pooling on tile shelf Texasguy Building & Construction 13 04-27-2007 08:14 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
help Chuckman Off Topic 8 06-15-2006 11:06 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
