White 4x4 Ceramic. - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 09-28-2010, 05:29 AM   #1
White 4x4 ceramic.
What are your views on Spectralock grout ? I'm doing a shower and I have well water with a high iron content . The store has recomened that I use this product.
uslayme is offline   Reply With Quote
Old 09-28-2010, 06:27 AM   #2
DIY staff
Rewards Points: 7,174
I use a lot of it---Be careful with the cleaning as you grout---there is not way to fix a sloppy clean up.
Reserve 2 new sponges for the final wipe down. Read the instructions --and then read them again.
Use an epoxy grout float---the product will melt a cheap black float----
All in all not bad to use---plenty of open time, Clean up of the tiles is not that hard--Read the instructions and have every thing that you will need on hand---Including some white scrub pads--just in case.------Good luck---come back and ask more questions----Mike---
Old 09-29-2010, 08:12 AM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Stay away from that stuff.
XXX
Old 09-30-2010, 07:20 PM   #4
DIY staff
Bud,Does someone else make a better epoxy?
Old 09-30-2010, 08:58 PM   #5
Epoxy grout = P.I.T.A.
JCW355 is offline   Reply With Quote
Old 10-02-2010, 06:25 AM   #6
DIY staff
It is a fine way to ruin a nice setting job if you don't get it perfectly clean,that's for sure.
No going back--only ripping it out and doing it over---Mike--
Old 10-03-2010, 04:12 PM   #7
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Not that I am aware of.
Laticrete seems to be the more advanced and user-friendly, if there is a such a thing. I basically refuse to deal with the crap.
XXX
black, white, white, black! bamaranch General DIY Discussions 5 07-04-2010 01:24 PM
Painting white martinigirl Painting 3 04-26-2009 07:24 PM
Off White Trim/Base/Crown with White Ceiling/Doors? StyxTx20 Interior Decorating 4 12-15-2008 08:54 AM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
Trim color and interior doors..white or off white? kristinnsmith Interior Decorating 3 04-22-2008 06:48 PM
