Where To Put The Tile Niche In The Shower? - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 10-21-2011, 12:26 AM   #1
Where to put the tile niche in the shower?
My layout doesn't work to have a full tile niche. I am not sure if I should have a grout line in it or whether I should scrap the whole idea and install corner shelves. I plan on using ditra in the niche and wonder if the buildup of ditra/thin set should be incorporated into the framing for a niche. I've posted a pic of the tile layout vs the framing. Any suggestions would be greatly appreciated.
Dean
Where to put the tile niche in the shower?-forumrunner_20111020_222511.jpg   Where to put the tile niche in the shower?-forumrunner_20111020_222556.jpg
DimeBag1976 is offline   Reply With Quote
Old 10-21-2011, 06:08 AM   #2
DIY staff
Rewards Points: 7,174
It sure would have been easier to do before you put up the backer board.
Often a niche looks good with the tile set on a diagonal--then matching up grout lines is eliminated.
Old 10-21-2011, 07:29 AM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
You wouldn't use DITRA in a niche.
You might use KERDI tho.
There are other ways to have a niche you know?
Old 10-21-2011, 09:15 AM   #4
Yeah I missed the boat when I had the tub out to reframe but my beautiful wife decided she wanted a niche after the fact. I should have known. And sorry, I meant kerdi, not ditra. When you say there is other ways, what did you mean?
Old 10-21-2011, 09:52 PM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Here is your "best-bet" now that you have gotten ahead of the game. These products will allow to remove only what is necessary to fit the niche into place. They are made to fit between two standard wall studs 16" on center.
If you need further installation suggestions speak up.
http://www.noblecompany.com/Portals/...00411%20lr.pdf
Old 10-22-2011, 12:21 AM   #6
Thanks for your help Bud and Mike. I'll offer all these options to the boss and let her decide. Fool proof plan... right?
Old 10-22-2011, 05:29 AM   #7
DIY staff
Nothing is fool proof----That's why they are called fools.
Old 11-05-2011, 02:48 AM   #8
Hey guys, just wanted to thank you for your input. Here's the final product, and the wife is really happy.
Old 11-05-2011, 05:46 AM   #9
DIY staff
Nice job. Excellent lay out.
Old 11-05-2011, 10:41 AM   #10
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Yow no kiddin' - that looks really good.
Old 12-04-2011, 12:52 PM   #11
Mark Daniels Kichen &Bath
Try this site for niches:
http://www.showershampooshelf-recess...ishholder.com/
Mark Daniels is offline   Reply With Quote
Old 12-04-2011, 03:16 PM   #12
For those diy'ers who look at this thread, I installed 2x4s perpendicular to the studs to frame my niche. Then put up hardi board up including the niche and taped all the seams. I tiled the insides with the same tile as the outside but cut the tiles for the inside to match the grout lines on the outside. In order to extend the bottom shelf of the niches out further I attached marble bullnose to the bottom outside of the niche. A more tedious and cumbersome job, but much cheaper than purchasing a niche.
amgdiy is offline   Reply With Quote
Old 12-05-2011, 10:30 AM   #13
Rewards Points: 304
Nice work Dimebag!
For your niche, and the small shelf you made inside the niche.. Is that just two bullnose style tiles stacked on top of each other supported on 3 sides (2 sides and the back)? I've seen niches done with just a plain "box" (by framing it w/ 2x4's), but that smaller shelf w/in the niche is very nice for things like soap/razor/etc. Nice job!
NewHomeDIYGuy is offline   Reply With Quote
Old 12-06-2011, 10:33 AM   #14
I actually bought a one-foot long piece of bullnose marble carrera. It's flat on top. I attached the bullnose to the outside bottom of the niche with the flat part facing up so that it acted as an extension of the niche's bottom shelf. I attempted to attach a picture. Don't know if it worked.Where to put the tile niche in the shower?-shower-july-2011.jpg
Old 12-06-2011, 10:43 AM   #15
Rewards Points: 304
Thanks amgdiy.. I'm familiar w/ how to make a niche (I generally just use bullnose tile), but I was wondering specifically how you make a niche w/ two "compartments" to it, like the other picture above. He made one niche, but it has a small lower compartment (for say soap/razors/etc), and a larger top compartment for shampoo/etc. Is it just two bullnose tiles back to back supported on 3 sides?
Tile or fiberglass shower? Proby Tiling, ceramics, marble 18 07-26-2010 04:49 PM
Shower tile specifics re: hair coloring Pammylu Tiling, ceramics, marble 4 06-05-2009 02:32 PM
Another newbie building a tile shower ChadC Building & Construction 7 08-25-2008 02:58 PM
Problem Glass Tile Shower robin2107 Remodeling 9 04-23-2007 08:19 PM
Building a tile shower ghostrider20 General DIY Discussions 2 03-01-2007 08:54 PM
