Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Flooring > Tiling, ceramics, marble
Old 02-10-2012, 07:03 PM   #1
where do you stop tile in doorway
Have a diagonal door to bathroom with 12 x 12 tiles (will BE). We were discussing where to stop ceramic tile. Directly under center of door, inside edge of door, outside edge of door even with stop,,,middle of stop,,,hallway edge of whole door frame.???????? Pro tilers have to have some standard. If it matters will probably have laminate similiar to "Pergo" on hallway/ living room bedroom ajoining
4just1don is offline   Reply With Quote
Old 02-11-2012, 02:26 PM   #2
Tileguy
JazMan's Avatar
Traditionally bathroom doorways have a marble threshold to function as a separator and for appearance. If you use a threshold you wouldn't have to ask the question since the marble is supposed to be 4.5", the thickness of the jamb. If you skip the threshold, I still recommend running the tile to the outside of the jamb. We do this for bathrooms only. All other doorways get the "change' under the closed door.
One additional benefit of the threshold is when visitors see the threshold or tile, they will know it's a bathroom.
Jaz
Tile 4 You LLC Troy, MI
KERDI Shower Specialist ... DITRA Installs ... Product-Method suitability consultation. I have NEVER made a mistake, I thought I did once...........but I was wrong! - PRODUCTS ADVERTISED WITHIN MY POST ARE NOT ENDORSED BY ME!
Travertine Tile Help MikeinTexas Flooring 1 09-07-2011 11:43 AM
Tile over Painted Lightweight Cement New_2_DIY Flooring 16 08-28-2011 03:29 AM
new ceramic tile over 12x12 ceramic danthebuilder Tiling, ceramics, marble 4 08-09-2011 01:03 PM
basement issues - tile, mastic, moisture pfisch Flooring 6 12-01-2008 02:35 PM
Tile roof questions/repairs help please xoroniox Roofing 3 12-17-2006 03:02 PM
