What Size Cemet Backer Board? - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 03-17-2013, 11:03 AM   #1
What size cemet backer board?
I am installing 20x20 Ceramic tiles in my kitchen and dining room. I have 23/32 osb on the floor currently with joists being 2x9 and 16 inches on center. The span of the joists is 11ft. What size cement backer board do I need for this application to support the 20x20 tiles, 1/2 or 1/4 inch and do I need to put down some plywood to help with the support? If so what size? Also will my joists be sufficient to support the weight? Any help would be great. Thank you.
handyman13 is offline   Reply With Quote
Old 03-17-2013, 11:29 AM   #2
Rewards Points: 528
1/4 is fine.
framer52 is offline   Reply With Quote
The Following User Says Thank You to framer52 For This Useful Post:
handyman13 (03-18-2013)
Old 03-17-2013, 05:01 PM   #3
Floor Installer
sam floor's Avatar
Rewards Points: 154
CBU adds no structural support. One of the tile guys should be along to let you know if your floor is OK.
sam floor is offline   Reply With Quote
The Following User Says Thank You to sam floor For This Useful Post:
Old 03-17-2013, 07:18 PM   #4
Tileguy
JazMan's Avatar
Rewards Points: 422
Yea, your joists are good enough for ceramic/porcelain as long as they're installed correctly and in good condition.
Your joists are 2x10", which measure 1.5"x9.25". 3/4" OSB subfloor is adequate too. It wouldn't hurt to add more ply if you want, the more the better. 1/4" CBU is intended for floors, use the thicker ones if you need the height. You could use Ditra or one of the Noble membranes instead.
Jaz
The Following 2 Users Say Thank You to JazMan For This Useful Post:
handyman13 (03-18-2013), JetSwet (03-18-2013)
Backer Board Minimum Dimensions? PPBART Building & Construction 4 07-13-2012 11:51 AM
installing hardy backer board for floor tile installation popeyemike Tiling, ceramics, marble 12 03-31-2012 03:02 PM
Some uneven spots on backer board scotte1975 Tiling, ceramics, marble 5 02-24-2012 01:55 PM
re-using concrete backer board caldew Kitchen & Bath Remodeling 2 02-24-2012 06:36 AM
Shower Pan- PVC Liner creating bulge in backer board Paul8434 Remodeling 1 06-07-2011 07:48 PM
