What Size Backerboard Do I Need On Floor? - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 10-06-2009, 11:35 PM   #1
Doing it myself
Alan's Avatar
Rewards Points: 2,086
What size backerboard do I need on floor?
I'm installing 12x12 ceramic tiles on 3/4" osb subfloor on 2x6 floor joists spaced 16" on center 5.5 feet unsupported span.
I'm not sure what thickness of backerboard I need. This is my first time, any other advice greatly appreciated.
Thanks in advance.
Journeyman Plumber
Old 10-07-2009, 06:58 AM   #2
1/4", unless you need more height, use 1/2".
Also that OSB is at the minimum for a tiled subfloor, if you have the room, add a layer of 1/2" plywood for a stronger floor.
R&D Tile is offline   Reply With Quote
Old 10-09-2009, 01:12 PM   #3
Doing it myself
Alan's Avatar
Thanks!
If the floor structure is borderline, would I be better off using a different product under the tile? IE : Wonderboard instead of hardibacker, etc etc...
Also : The room i'm tiling is less than 50 square feet, so I'm probably not going to be making too many cuts if I lay it out properly. What kinds of things can i use to cut tile rather than buying a 500 dollar tile saw?
Journeyman Plumber
Old 10-09-2009, 01:54 PM   #4
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,074
You can rent that 500 dollar tile saw.
You can buy a cheaper ($60.00 to $90.00) tile saw. I did this option when I tiled my bathroom (first-timer).
If you bought your tiles at an apron store, some will do cuts for a small fee.
There are also score-and-snap tools. I assume they work best on the thinner subway tiles. If your tiles are as think as mine were, I don't think I would go that route.
Removed basement stairs - put in floor for washer and dryer capslock Flooring 3 10-09-2010 03:15 PM
Hardwood floor questions (56K) ukrainetz Flooring 1 08-02-2009 02:08 PM
Movement in bathroom floor rob_di_mostly_y Kitchen & Bath Remodeling 2 07-24-2009 04:37 PM
Room size X floor tile size deck hand Flooring 4 04-08-2009 05:42 PM
Carpet in the basement Packer Backer Flooring 16 11-04-2008 12:19 AM
