Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Flooring > Tiling, ceramics, marble
Old 01-30-2013, 03:09 PM   #16
"You can do anything"-Mom
brockmiera's Avatar
What is the point of grout?
Originally Posted by jeffnc View Post
Water getting behind tiles will not cause them to fall off or get weak or anything like that. Whether you use grout or not, you should assume water is always getting behind your tiles.
I'm also skeptical about your reason for saying larger tiles "call for" larger gaps - what is this supposed to mean?
I think he meant because the larger tiles typically have bigger degrees of inconsistency. Therefore, to keep your tiles in line horizontally and vertically you would need bigger grout lines.
brockmiera is offline   Reply With Quote
Old 02-01-2013, 04:01 PM   #17
Originally Posted by brockmiera View Post
With this line of questioning comes another one. I assume that I will need a large notched trowel for the big tiles and a smaller one for the 1x1 mosaic tiles. How will I keep them flush with each other on the wall if I'm using a different depth of thinset?
Use more thinset, to bring the mosaic tiles to the same height.
I really don't like this idea of not using grout. Expect a smelly mildew/mold problem in a few months.
Seattle2k is offline   Reply With Quote
Old 02-01-2013, 05:21 PM   #18
Tileguy
JazMan's Avatar
That isn't gonna work. You have to push the tiles into the thinset you know. There's other ways, but not more thinset.
That I agree with.
Jaz
Tile 4 You LLC Troy, MI
KERDI Shower Specialist ... DITRA Installs ... Product-Method suitability consultation. I have NEVER made a mistake, I thought I did once...........but I was wrong! - PRODUCTS ADVERTISED WITHIN MY POST ARE NOT ENDORSED BY ME!
Repairing missing grout in shower stall CLM Tiling, ceramics, marble 14 10-03-2010 11:08 PM
What works and what doesn't to clean grout? groutresearcher Flooring 2 09-04-2008 11:49 PM
Cracking floor grout - Ceramic tile DeepDish Building & Construction 9 08-27-2008 10:51 PM
sanding grout C99 Flooring 4 02-18-2008 06:10 PM
Tinting/re-coloring grout proofer Flooring 7 02-02-2008 11:59 PM
