What Notch Trowel For 12x24 Porcelain On Wall? - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 03-22-2011, 01:13 PM   #1
Rewards Points: 12
What notch trowel for 12x24 porcelain on wall?
yet another trowel question,
Thanks in advance
--Gil
g9_diy is offline   Reply With Quote
Old 03-22-2011, 05:37 PM   #2
1/2 inch square notch.
I just put up a bunch the other day.
What thinset are you using?
williamwiens is offline   Reply With Quote
Old 03-22-2011, 05:42 PM   #3
Rewards Points: 12
Either versabond from HD
Or mer-krete pro set plus from hd supply.
Old 03-22-2011, 05:47 PM   #4
DIY staff
Rewards Points: 7,174
Consider using 'lash clips' to help prevent lippage.
It's a T-shaped plastic piece with a wedge.---I'll see if I can find a link to a picture.
QEP | Lash
Many companies make clips like these---others may be better.
Old 03-22-2011, 06:12 PM   #5
Rewards Points: 12
Thanks Mike, i'll take a look when im out shopping for that 1/2" notch. Square or U shape? Any advantage, disadvantage to U over Square?
Old 03-22-2011, 06:22 PM   #6
DIY staff
All mine are square---never tried the arch top ones.
Here is a fun post to read---Tuscan Leveling System - Flooring Picture Post - Contractor Talk - Professional Construction and Remodeling Forum
Depot carries the lash clips.
Old 03-23-2011, 02:56 PM   #7
Rewards Points: 12
Anyone familiar with Mer-krete 705 or 710 ?
http://www.merkrete.com/products.pl
I will be using 12x24 porcelain on shower wall
Are either of these good for my application?
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 6 05-19-2017 04:53 PM
Removing spine wall beko Building & Construction 12 02-02-2010 01:15 AM
Can I install 12x12 porcelain tile on a shower wall or ceiling? dezigner80 Remodeling 6 09-15-2009 12:05 PM
Removing a 4 foot opening in a load bearing wall (for fish tank) ~callie~ Building & Construction 1 07-15-2009 05:10 PM
