I need to remove a plastic nut, It is hiding and cannot get my hands around it, to remove.
I have been told to use "channel lock"? What are they? What do they look like?
Also, if I am installing marble on my bathroom wall, what adhesive would I use? Do I need to use this mastic stuff, or can I use regular thinset, white, for marble?
Channel lock pliers. I think this person is suggesting instead of coming at it from the side, as you would an open-ended wrench, put the pliers on it over the top (see the link below, instead of a nail, picture the nut/bolt).
In your case (by the way, why isn't this project finished by now?) the channel locks will allow you to reach into the wall from the front to loosen that nut.
Use white thinset for your marble. It doesn't necessarily have to be specifically for marble if you have the regular stuff on hand from one of your other projects.:wink:
I would use a 1/8" X 1/8" square notch. You won't find one in the tile department but you will in the wood department. They are primarily used for gluing wood flooring I think.
My second choice would be a 3/16" X 3/16" "V" notch.
I am going to look for some marble tiles. The ones with the mesh backing or some rectangular ones where I can install them vertically.
Related Threads
DIY Home Improvement Forum
3.1M posts
319.5K members
Since 2003
