What Caused My Grout To Do This? - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 01-28-2010, 10:28 PM   #1
jackie treehorn's Avatar
Rewards Points: 174
What caused my grout to do this?
Is the discoloration from not mixing well enough? I mixed the grout till I thought my hand was gonna fall off, then I let it slake for over ten minutes. Thoughts?
jackie treehorn is offline   Reply With Quote
Old 01-29-2010, 12:44 AM   #2
Efflorescence. Caused by to much moisture, either when the grout was mixed, when the tiles where cleaned or the thinset wasn't dry when the grout was applied. Sometimes it can be removed by vinegar. Don't overwet the grout when cleaning this off, to much moisture was the cause in the first place. Other acid washes are available.
Work is for those who can not fish.
Mop in Hand is offline   Reply With Quote
Old 01-29-2010, 11:36 AM   #3
Rewards Points: 174
Thanks!! I guess it's vinegar or a do-over
Old 01-29-2010, 08:02 PM   #4
scrub brush and vinegar should fix it. some times it will just scrub off dry. i would not use any acid. acid wont fix grout. good luck.
just tile is offline   Reply With Quote
Old 01-29-2010, 08:47 PM   #5
If that doesn't work try this http://www.custombuildingproducts.co...er=arc&lang=en
another grout color change question tryinitmyself Flooring 1 02-22-2008 07:50 PM
sanding grout C99 Flooring 4 02-18-2008 06:10 PM
Tinting/re-coloring grout proofer Flooring 7 02-02-2008 11:59 PM
Cracking floor grout - Ceramic tile DeepDish Flooring 9 03-03-2007 08:49 PM
