What is the best way to remove this tiling and how much to remove?
1 Attachment(s)
My wife finally sold me the idea we could redo our small bathroom.. After removing the old wallpaper, the sink and the cabinet, I am stomped with how to remove the tiling most efficiently. The picture is from where the cabinet was. It looks like I have a cement layer set in there, then there is the white material that looks like cement mortar but this one is really hard. I tried to chip with a chisel and a hammer and I feel it can take hours and my old back will not like it much.. The house was built in 1970 and I think this is the original tiling from then. We want to replace the ceramic tile with cork or bamboo tiles/planks. My questions are:
1. What is the best way to remove the tiling and the white mortar? I read a number of earlier posts that talked about an electric hammer. I am considering either that or hiring someone. 2. Do I need to remove the cement backing and how? thanks! |
A few more details-----Is this on a concrete slab or a wood subfloor---
If it's over concrete---rent a chipping hammer with a flat blade---you will have it off the floor in a hurry--- |
This bathroom is on our second floor and on wood subfloor. I read about chipping hammer on other posts.Will it still work?
1 Attachment(s)
Yep, chipping hammer will do it quickly.
I have one of these, would recommend just renting one though. Blade will be about a 1 1/2" wide. Just tell the person at rental yard what you want it for, will set you up with what you need. |
Is it set on the subfloor or is there a layer of underlayment?
If there is an underlayment---get a flat bar under it and drive it inbetween the subfloor and the underlayment and remove this and underlayment all at once--- If it's set right on the subfloor---I suggest banging on the tile with a big hammer---the tile usually bounced right off the wood--- And Yes--that chipping hammer will work--- |
First of all. I'm not sure about cork, but bamboo in a full bathroom is not a good plan. I would think cork isn't much better, but maybe not.
What you've got there is a basic plain old mud job. It's made like so..... Tarpaper over the wood subfloor. Metal lath stapled over that. A mix of sand/cement about 3/4" thick placed and leveled. Then tiles installed with thinset mortar. (that white stuff). Removed it all down to the subfloor. Start at doorway with 2 lb. hammer and crowbars. Pry it up being careful not to get violent so you do not damage the plywood. Also need wire cutters - tin snips to cut lath. Makes lots of dust. Also get leather work gloves. Once the old mud is gone you might/should need to add more underlayment depending on condition and what you're installing. (hopefully nothing made of wood). Jaz |
Duplicate post, site acting weird last 2 days.
| All times are GMT -4. The time now is 05:51 PM. |
