Wet Bed Or Thin Set With Ditra For Stone Tiles - Tiling, ceramics, marble - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-29-2013, 07:42 AM   #16
DIY staff
Rewards Points: 7,174
Very true----the old framing in your house may well have old growth fir floor joists----which are stronger than modern wood----
Old 08-29-2013, 07:43 AM   #17
DIY staff
1 1/2" x9 1/4"
Old 08-29-2013, 08:28 AM   #18
Rewards Points: 4,796
Originally Posted by Igghy View Post
Is 2x10 true measurement or is it more like 1 3/4" by 9.5" in practice?
It's about 1 1/2" x 9 1/2", but whenever an industry standard like 2x10 is mentioned, that's what they mean. 2x10 is an example of a "nominal" measurement - an agreed upon standard even though the real measurement is different.
jeffnc is offline   Reply With Quote
The Following User Says Thank You to jeffnc For This Useful Post:
Igghy (08-29-2013)
Old 08-29-2013, 10:16 AM   #19
Thank you. Why is it recommended to sister in rather than just add extra joists in the middle space?
I don't know if our joists are old growth timber but they appear in good shape.
Igghy is offline   Reply With Quote
Old 08-29-2013, 04:14 PM   #20
DIY staff
It's easier to sister than to space them----once that floor is opened up you will see why---the open space between the joists is used for heat ducts--electrical and such----
Old 08-30-2013, 07:18 AM   #21
Would you say it's worth saving and reusing tongue and grooved solid wood the subfloor that we will be taking out? It looks in good shape.
Old 08-30-2013, 07:26 AM   #22
DIY staff
Not at all----junk the old T&G ---if you replace that with 3/4" BC plywood you can place your tile backer right over that without the need to add ply over the T&G---
Some might wish to add a second layer of 1/2" BC ply on top of the 3/4" for more stiffness.
Solid wood moves a lot throughout the year----that is why I say junk it---
Old 08-30-2013, 12:34 PM   #23
Does 1/2" ply on top of 3/4" replace tile backer? Is there anything else we should do while the floor is open? Thank you so so much!
Old 08-30-2013, 05:10 PM   #24
No it doesn't replace the backer (that doesn't make sense - it's just more plywood.) But a 1 1/4" subfloor is super sturdy. Ditra is still the best tile backer on top of that IMO.
Old 08-30-2013, 05:17 PM   #25
DIY staff
Jeff is correct---you will need to add a tile backer on top of the plywood to ensure a good bond---1/4" Durrock or Wonderboard set in a bed of thinset,much like a giant tile--then nailed with roofing nails or rock screws--
Ditra is ideal for natural stone ---but,done properly,either will work.
Old 08-30-2013, 06:50 PM   #26
Thank you. 1 1/4" subfloor, heat mat, Ditra, then tiles? Would it do?
Old 08-30-2013, 06:57 PM   #27
DIY staff
I'm not familiar with Ditra---I'm kind of old fashioned--
Jaz is an expert with that product and can guide you better than I can.
Old 08-30-2013, 07:27 PM   #28
I haven't installed it, but that's the order according to Schluter. You will have to read the instructions for the heat mat, but Schluter gives a little information on page 12.
http://www.schluter.com/media/DITRAH...v=201308300605
Old 08-30-2013, 09:00 PM   #29
Tileguy
JazMan's Avatar
Rewards Points: 412
A slight correction since this is a stone tile install
That's right for ceramic but not for stone tiles. For stone you always need a two-layer subfloor. So in this case I would junk the 3/4" planks, replace with 3/4" ply/OSB subfloor, then 1/2" underlayment grade ply.
That's it, you've got it. What brands of thin set are available to you?
Jaz
JazMan is online now   Reply With Quote
Old 08-30-2013, 10:33 PM   #30
Why is that, do you know?
Tags
tiling floors
Ditra or Hardibacker? bluefoxicy Tiling, ceramics, marble 15 01-10-2013 09:00 PM
remove hardened thin set from ceramic tile DvanDee Tiling, ceramics, marble 2 08-27-2012 11:45 AM
6"x6" porcelain tiles?????? Quickdraw Flooring 15 12-04-2009 06:29 AM
calking backer board to tub glassman General DIY Discussions 13 06-19-2008 08:41 PM
TrafficMaster grout f.y.i. denman Flooring 16 07-01-2007 03:07 PM
