Waterproofing A Tiled Shower - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 02-03-2012, 10:26 AM   #1
Waterproofing a tiled shower
I'm planning to rebuild the tile shower in my bathroom with another tiled shower, with no fiberglass pan or walls, just tile throughout. I'll gut the bathroom down to the studs, and replace the subfloor if necessary. Then, I'll build up the base of the shower with 2x4s.
Many books and online tutorials show a multilayer process for the shower floor, one layer of which is a CPE waterproof membrane. My questions is, is it possible to use a spray on rubber coating, or other method to waterproof the shower floor instead of the membrane? It seems a sprayed on liner might be more waterproof, because there is a potential for unsealed areas in the folded membrane. I'm not sure of the durability of a sprayed waterproofing material vs a membrane?
gbook2 is offline   Reply With Quote
Mating tiled wall to fiberglass shower pan? lizardrider Kitchen & Bath Remodeling 6 05-15-2011 01:21 PM
Failed shower pan in old tiled shower tmpyankee Plumbing 3 07-14-2010 06:43 AM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 06:33 AM
Questions on waterproofing tile walls for shower with floor pan. HautingLu Tiling, ceramics, marble 11 09-18-2009 11:12 AM
New tiled shower won't drain; mortar in drain. catitudes Plumbing 5 03-29-2009 01:08 PM
