Want To Put Tile In A Fireplace Hearth... - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 02-15-2014, 10:24 AM   #1
MarginallyQualified
Rewards Points: 2,464
Want to put tile in a fireplace hearth...
...a used hearth. With soot on the walls.
1) What sort of tile/mastic can take radiant heat from a little wood stove?
2) What surface prep is needed to get the mastic to stick?
iow... how best to clean it and how clean is "good enough"?
Old 02-15-2014, 10:45 AM   #2
DIY staff
Rewards Points: 7,174
You need a cement based powdered modified thinset---and to deal with the possible expansion due to the heat--a good one---high polymer count---
Look for the word 'flexible' or similar in the name----
As to clean? Wash the old brick with soap and water---you want to be sure there is no grease or other bond breakers like that--but brick is a good surface for tile---and a fireplace is not likely to be greasy----
Old 02-15-2014, 11:54 AM   #3
DIY staff
oops---you meant the fire brick inside!
Use TSP and a stiff scrub brush to remove the soot----the fire brick is soft---some sanding will also work if the TSP fails----then use a food modified thinset--
Old 05-15-2014, 05:24 PM   #4
MarginallyQualified
dirty job for a rainy day
It only took me 3 months and it ade a gawd awful mess...
but I got to it today and it came out pretty good.
Ended up going straight to the abrasives with a wire brush cup on an angle grinder (took two of them to finish) along with the shop vac and a drop light.
Want to put tile in a fireplace hearth...-hearthclean1.jpg   Want to put tile in a fireplace hearth...-hearthclean2.jpg
The Following User Says Thank You to TarheelTerp For This Useful Post:
oh'mike (05-15-2014)
Best way to lay tile on fireplace? Bennylava Remodeling 9 09-21-2013 06:31 PM
Fireplace hearth weight marriedmanw Building & Construction 0 10-08-2012 05:22 PM
Tile and wood over painted brick fireplace OddBuffalo Concrete, Stone & Masonry 0 08-17-2012 08:15 AM
Asbestos Removal, Porcelain Tile Installation jimbriam Flooring 15 01-30-2012 01:46 PM
tile fireplace surround and floor-help. moyni51 Flooring 1 08-07-2011 07:50 AM
