-   Tiling, ceramics, marble (http://www.diychatroom.com/f84/)
-   -   Want to put tile in a fireplace hearth... (http://www.diychatroom.com/f84/want-put-tile-fireplace-hearth-196291/)
TarheelTerp 02-15-2014 10:24 AM
1 Attachment(s)
...a used hearth. With soot on the walls.
1) What sort of tile/mastic can take radiant heat from a little wood stove?
2) What surface prep is needed to get the mastic to stick?
iow... how best to clean it and how clean is "good enough"?
oh'mike 02-15-2014 10:45 AM
You need a cement based powdered modified thinset---and to deal with the possible expansion due to the heat--a good one---high polymer count---
Look for the word 'flexible' or similar in the name----
As to clean? Wash the old brick with soap and water---you want to be sure there is no grease or other bond breakers like that--but brick is a good surface for tile---and a fireplace is not likely to be greasy----
oh'mike 02-15-2014 11:54 AM
oops---you meant the fire brick inside!
Use TSP and a stiff scrub brush to remove the soot----the fire brick is soft---some sanding will also work if the TSP fails----then use a food modified thinset--
TarheelTerp 05-15-2014 05:24 PM
dirty job for a rainy day
2 Attachment(s)
It only took me 3 months and it ade a gawd awful mess...
but I got to it today and it came out pretty good.
Ended up going straight to the abrasives with a wire brush cup on an angle grinder (took two of them to finish) along with the shop vac and a drop light.
