-   Tiling, ceramics, marble (http://www.diychatroom.com/f84/)
-   -   Wall tile - five questions (http://www.diychatroom.com/f84/wall-tile-five-questions-68465/)
CZ DIY 04-06-2010 08:14 PM
Guys, I'm remodeling my bathroom.
The tub is an enclosed unit, so I don't need to worry about that. I'm tiling all walls from the floor to the 8' ceiling. The drywall is greenboard.
1) Can I use ceramic floor tile on my walls? It's thicker, but the style I like is available only in floor tile.
2) Do I really need concrete backer board for the wall tile? It's not in the shower, just in the rest of the bathroom walls. And there is plenty of ventilation.
3) Is the tile you find at Home Depot/Lowes going to be a good deal, or should I be looking at local retail shops instead?
4) Should Install my sink vanity cabinet and wall tile around it, or just tile the entire area and then install the cabinet?
5) Should I primer the walls before tiling or does it matter? Right now it's just tape & 3 layers of mud.
Thanks!
jlhaslip 04-06-2010 08:45 PM
1. using floor tile on a wall is okay. not the other way around. 2. no backer required on walls. use mastic or thinset. your choice. 3. wouldn't hurt to shop around. 4. install first. 5. prime first.
CZ DIY 04-07-2010 12:20 AM
Thanks. :)
Blondesense 04-07-2010 02:22 PM
One thing to watch for is a consistent size. If there is much variation, a wider grout line will make things easier.
It's a Tomato, To-mah-to thing. It can be done both ways. Tiling first uses more tiles, but tiling a flat wall and floor is easier than cutting pieces to fit around the vanity.
In your shoes, since you are doing the walls and (I assume) using a fairly smooth ceramic tile, I might consider tiling first, skipping the tiles for the plumbing rough out and any cabinet fasteners. That way, if down the road someone wanted to change out the vanity patching the walls and floor wouldn't be too much of an issue. Otherwise changing the vanity could pretty much require the whole bathroom be re-done.
Then stash your leftover tiles in the back of the garage just in case.
CZ DIY 04-24-2010 02:44 PM
I just noticed this reponse. Thanks for the info. I actually would prefer to tile everything and then install the cabinet afterwards, exactly for the reasons you suggested. I just wasn't sure if that was a no-no for some reason.
I'm shopping for a tile cutter on eBay today. Hoping to pick up tiles sometime this week or next.
I should be priming the walls this week, assuming I finish mudding tomorrow as planned. Everything takes 4x longer than you think it will. Especially when you're doing it all yourself and you're a first-timer. :eek:
