Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Flooring > Tiling, ceramics, marble
Old 03-25-2012, 09:05 PM   #1
vinyl tile over sheet vinyl
I have a sheet vinyl tile floor that looks sorta like 4" tile with grout in my kitchen (350 sq.ft) and want to replace it with vinyl tiles. The floor is not level. My husband pulled up a little piece of it and found that it is glued to the subfloor...no underlayment at all. We have gotten 4 different pieces of advice. 1. Tear up the floor (which sounds like a monumental job) 2. Lay the vinyl right over the existing vinyl (won't the pattern come through?) 3. Lay luan over the existing floor and tile over it, which seems like it will raise the floor (tripping hazzard) and 4. Cover it with leveling compound. I don't like my choices so far!! What do you think?
CaroleNJ is offline   Reply With Quote
Old 03-26-2012, 02:25 AM   #2
The old pattern would "telegraph" through the new vinyl.
Cement based Leveler with latex additive (some have it in it already) not a gypsum based Leveler would work.
The old vinyl must be clean and wax free.
Older vinyls contained asbestos and requires abatement to safely remove it.
You can not look at it and determine if it has asbestos. It was outlawed in the '70's but material in the supply chain was allowed to be sold. You may have bought vinyl in 1980 that was made back then.
Unless you have it tested; cover, don't scrape or sand.
Luan is the wrong wood. It will delaminate & buckle. 1/4" CDX should be used, properly nailed, & floated with the cement/latex mixture. Allow small expansion joints & stagger joints. Lightly sand leveler & vacuum good!
cer2012 is offline   Reply With Quote
Old 03-26-2012, 02:37 AM   #3
CDX should never be used as an underlayment. It has void and unfilled knot holes in the core. Use 1/4" A/C underlament rated plywood instead.
It has more plys, no voids, ext. glue.
cer2012 (03-26-2012)
Old 03-26-2012, 03:28 AM   #4
Wasn't thinkin right. Answering a question elsewhere about sheeting underlay for carpet and lost track of my marbles for a second. I did recommend underlay board tho. Thanks for catching that boo boo.
When I first started laying floors the dealer would send us out with luan. That stuff will swell and delam as soon as you walk out the door.
Thx again for the catch!
Old 03-26-2012, 08:07 PM   #5
Thanks so much for such fast replies. I really appreciate that you share your expertise and experience!
Looks like laying the tiles over the existing floor is out. The floor was installed in 1986, and if I recall correctly it was a new product then, so I am fairly sure that asbestos is not a problem.
Am I correct in believing that the easiest route to go is using leveling compound or 1/4 " A/C? The vinyl would add another 1/8". Is it okay to raise the floor 5/8 of an inch. (there are 3 doorways coming into this room.)
Thanks again. You guys are so very helpful!
Old 03-26-2012, 09:31 PM   #6
JetSwet's Avatar
Sanded cdx, sorry Joe I always use it for flooring underlayment eeek! Lol
JetSwet is offline   Reply With Quote
Old 03-26-2012, 10:12 PM   #7
Tileguy
JazMan's Avatar
Yes Joe, Jet has no regard for specifications or rules. He uses the cheapest ply available and heck with it.
To the rest of you reading this thread (and this forum actually), please do not follow the instruction this man from NY comes up with. It's often very wrong.
Hopefully someone will help him learn the right way to do flooring.
Jaz
Tile 4 You LLC Troy, MI
KERDI Shower Specialist ... DITRA Installs ... Product-Method suitability consultation. I have NEVER made a mistake, I thought I did once...........but I was wrong! - PRODUCTS ADVERTISED WITHIN MY POST ARE NOT ENDORSED BY ME!
Old 03-27-2012, 12:02 AM   #8
You could remove the top layer of the vinyl. Use a utility knife to cut thru the top wear layer and peal it off. Will only work if the vinyl is well adheared.
I will say if it is cushion vinyl, remove it! Sometimes it is easier to remove the layer of subfloor and replace it.
Be sure substrate is smooth and level. ANY imperfection WILL show thru! Skim coate according to directions.
Nail new board 4" on edge an 6" grid in center. Start in center and work outward and use screws or screw nails or ring shank. Galvanized is best but the have to be rust resistant and sank just below flush, like drywalling. Float joints and heads and sand smooth (wear a mask).
Vacuum floor 2 times don't damp mop! You would have to allow a day or so to let it dry completely.
Old 03-27-2012, 06:03 AM   #9
JetSwet's Avatar
Jaz
Oh Jaz..... "you" my friend will be the 1st one I will let know when any cdx floor job I have done fails and also the many other installers I know that use it, if there's fails as well I will let you know believe me.
Old 03-27-2012, 07:40 AM   #10
Pro Flooring Installer
rusty baker's Avatar
If you want to make mistakes, that is your choice. But why tell DIYers the wrong way? No vinyl company will warranty vinyl installed over cdx.
"I'm twisted, not sick. Sick implies, I'll get better"
Semi-Retired Installer
Installing since 1973
Old 03-27-2012, 08:32 AM   #11
JetSwet's Avatar
I guess I walked into a land-mine of right way or high way with this one.
Aren't ac - Bc and cdx exterior rated there in the same family just which one is the smoothest ac yes but cdx can be just as smooth if sanded.
Old 03-27-2012, 09:29 AM   #12
No vinyl company will warranty vinyl over cdx. That is what should matter.
Old 03-27-2012, 09:37 AM   #13
JetSwet's Avatar
But they will warranty over ac ply?...
Old 03-27-2012, 09:46 AM   #14
Only if it's stamped "underlayment grade".
Old 03-27-2012, 10:15 AM   #15
JetSwet's Avatar
Thanks sorry about that.
Have this sheet vinyl floor asbestos tested? CoconutPete General Discussion 11 01-21-2012 11:39 PM
Vinyl sheet flooring & allure klmeenan Flooring 11 05-28-2011 01:39 PM
Tile over sheet vinyl? jonathan03 Flooring 1 07-06-2010 06:36 AM
Back Splash Tile Over Old Sheet Rock? Stcrosby Remodeling 3 01-03-2010 01:46 PM
Vinyl tile over luan? irishghandi Flooring 1 03-08-2006 03:46 PM
