Vinyl Sheet Tile Install - Remove Or Level Ceramic? - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 01-13-2012, 03:56 AM   #1
Vinyl sheet tile install - remove or level ceramic?
I have a 4' x 4' area just inside of my front door. Right now it is covered with ceramic tiles that are 6" x 6" with 1/4" wide grout between. My wife has some vinyl sheet tile picked out that she would like in its place. My question is do I just use leveler to bring the grout cracks to level with the tiles, or should I just take the time to remove the old tile/glue before laying the new vinyl sheet?
I have laid vinyl sheeting a few times, but always on top of new subflooring. Would the ceramics be an o.k. base to glue vinyl to?
Craig
Craigkapo is offline   Reply With Quote
Old 01-20-2012, 07:34 AM   #2
mike owes me $53 dollars
Tech Dawg's Avatar
Craig,
In using an SLC you will add more floor height as well. Your best option is to tear it down, add your BamPly underlayment as needed then your vinyl
Tech Dawg is offline   Reply With Quote
The Following User Says Thank You to Tech Dawg For This Useful Post:
oh'mike (01-20-2012)
Old 01-21-2012, 12:53 AM   #3
Whatever you do, use the leveler - vinyl always depresses/adapts to whatever is under it and shows the same texture. Even a tiny bit of dirt eventually looks like a pimple (or volcano, in the eye of a critical beholder). That means the "removing the tile option" needs be done thoroughly and any pits you make be filled/leveled.
Actually, whether you need remove the tile depends on the adjacent flooring, The vinyl will add 1/8 at least, to the height. Next to carpet, little matter. Next to hardwood or other composite will make an uneven juncture. You be the judge.
bareshiyth is offline   Reply With Quote
Old 01-21-2012, 01:13 AM   #4
Rewards Points: 14,306
Not if they use the required 1/4 underlayment rated plywood under it.
DO not use louon!
New porcelain tile to replace vinyl floor in kitchen PatrickGSR94 Flooring 5 03-03-2011 01:42 PM
Remove ceramic tile from radiant floor dallas/sasha Flooring 1 05-21-2010 10:35 PM
Remove 3/4" oak floor before cement board and ceramic tile goes down?? 4just1don Flooring 8 10-31-2008 10:32 AM
Concrete prep: how to remove old adhesive/grout etc from ceramic tile? Matt Devo Flooring 5 10-01-2008 08:53 PM
Sheet Vinyl Flooring Removal yoods Flooring 2 11-22-2007 12:04 PM
