Vertical Corner Joints Cracking In Shower - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 02-07-2010, 10:05 AM   #1
Vertical corner joints cracking in shower
A lot of the work done by the previous owners of our wasn't entirely correct. We've developed some pretty serious vertical cracking in the grout along the inside corner joints in our tiled shower. For what it is worth, the tiles are just simple 1" square ceramic tiles and we don't really have cracking anywhere else. The major crack is in the corner behind the shower head, so it doesn't get hit by the water directly.
From what I have read, it seems as though they should have used caulk rather than grout. So, what do I need to do here? I am sure I need to remove the existing grout and then caulk the joint, but I am not sure how best to handle it. This is our only shower and my understanding is that caulk needs to be applied to a perfectly dry surface and then allowed to dry, but we don't have that luxury. Is there a special type of caulk I can use that works better with wet surfaces and/or dries quickly? Has anyone had any luck taping plastic over an area like this? Other thoughts? Suggestions?
We will be remodeling the entire bathroom in 2-3 years (after we add an additional bathroom this coming year), so the solution doesn't need to last 15 years.
stubits is offline   Reply With Quote
Old 02-07-2010, 11:39 AM   #2
jlhaslip's Avatar
Rewards Points: 1,100
you can apply a clear silicone caulking into the corner that is cracking over top of the grout as a temp fix.
Originally Posted by Bud Cline View Post
Go ahead and apply for a variance, those guys at City Hall can use a good laugh.
jlhaslip is offline   Reply With Quote
Old 02-07-2010, 01:46 PM   #3
Rewards Points: 4,538
PLEASE DO NOT QUOTE ME WITHOUT REMITTING A LICENSING FEE
as for the repair suggested, he's right - no charge !
Tile Baseboard on outside of plastic shower pan at linoleum joint? GaryS Tiling, ceramics, marble 2 07-26-2009 01:39 PM
Molding in shower..wall cracking! Pleasuremann General DIY Discussions 4 04-19-2009 10:47 PM
cracking corner of newly tiled shower stall jmuamy General DIY Discussions 10 04-14-2009 09:38 AM
Shower floor grout cracking radnrs Flooring 11 09-14-2008 09:49 PM
Who makes a good corner shower??? murray59 Plumbing 3 06-03-2008 03:26 PM
