Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Flooring > Tiling, ceramics, marble
Old 01-24-2011, 09:43 PM   #1
Vapor barrier in tub/shower stall with exterior wall... OK to install Schluter-KERDI over concrete board?
Can I use a product like Schluter-KERDI as a vapor barrier in the situation described below?
- Application on top of concrete board in a three-wall shower/tub stall (to be followed later by application of tiles on top of the Schluter-KERDI)
- One wall of this shower/tub stall is an insulated exterior wall on the north-facing side of the house in a cold, dry climate (Colorado)
- There is currently no other vapor barrier installed behind the concrete board, which has been installed directly onto the studs
... or will this cause problems down the road?
The reason I am asking: the standard out here in Colorado seems to be clear plastic vapor barriers BEHIND the concrete board.
I guess the question could also be asked like this: if tile could be applied directly on top of a clear plastic vapor barrier, would these vapor barriers all be installed on top of the concrete board instead of behind it?
Thank you SO MUCH for your assistance. I want a 100% perfect installation, and have been agonizing somewhat over this question.
tzinho is offline   Reply With Quote
Old 01-24-2011, 09:58 PM   #2
Tileguy
JazMan's Avatar
Hi,
Vapor barriers are a very confusing subject. Go ahead and install the Kerdi membrane and leave the barrier on the insulation as is. You do not want plastic on the studs behind wall board or concrete board and a surface membrane too. One or the other, not both. But.....the surface membrane is much better cuz it keeps the substrate dry.
So, yes. That's why you've chosen Kerdi, consider it a plastic you can tile over.
Jaz
Tile 4 You LLC Troy, MI
KERDI Shower Specialist ... DITRA Installs ... Product-Method suitability consultation. I have NEVER made a mistake, I thought I did once...........but I was wrong! - PRODUCTS ADVERTISED WITHIN MY POST ARE NOT ENDORSED BY ME!
Cement backer board over kitchen concrete slab gtimk4 Flooring 2 02-19-2012 03:46 PM
Need to Install Hand Rail on Basement Stairs, but on Concrete Wall Firehawk734 Building & Construction 40 01-18-2012 09:33 AM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
Preparing to install Kerdi on bathtub surround DIY-Renovator Flooring 18 07-17-2008 11:42 AM
