Using Sanded Caulk - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 07-03-2013, 11:53 AM   #1
Using Sanded Caulk
I visited large professional tile store and purchased their sanded caulk for a shower.
I removed very hard grout completely. Used almost all of the sanded caulk on each of the 4' edges of the shower (varing in size 1/16-3/8").
I waited 3 days after removing the grout that was cracked, stained etc. prior to caulking. I then waited 24+ hours before using the shower as per the cure time on tube.
Problem = the caulk has somewhat sunk in so a very little amount of water rests on it. The caulk remains soft ...
Do I remove and start over and allow the caulk to cure for 48+ hours? Or is the softness customary and deal with it?
In a effort to fill in the low area .. would a small bead of caulk bond to exsisting caulk?
I am starting to question the quality of product from the tile store and may be better off saving a few dollars at big box stores.
akaJoe is offline   Reply With Quote
Tags
caulking , grout caulk shower tile
Recaulking at previously silicone-caulked shower door frame hffeagan Kitchen & Bath Remodeling 37 06-05-2017 05:19 PM
Why can't you use sanded CAULK for ALL tile joints in your shower? l3randonf Tiling, ceramics, marble 4 09-30-2012 08:30 PM
What type of Caulk to Use Einhorn General DIY Discussions 19 08-21-2011 02:50 PM
Sanded vs non-sanded caulk sukhenkoi Kitchen & Bath Remodeling 1 05-17-2011 06:48 PM
Sanded Caulk or 100% Silicone mikejones Tiling, ceramics, marble 2 10-26-2009 08:07 PM
