Using Masonry Type S And Lathe To Level Floor - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 12-16-2012, 04:10 PM   #1
Rewards Points: 330
using masonry type S and lathe to level floor
I need to raise one side of my bath 3/4'' to bring it to level..
before I lay the tile.
The house is a 1930's pier and beam with2x8 joist 24'' OC - 1x8 CM sheathing and 1 layer of 3/4'' fir subfloor
I have 3 bags of Type S masonry mortar left over I want use
$24 is $24 right ? type S is portland and sand with some lime thrown in?
Can I nail down my lathe and build the low side up with
the type S and feather in with a self leveling product?
kt82 is offline   Reply With Quote
Old 12-16-2012, 06:07 PM   #2
Rewards Points: 13,300
What's the clear span on the joist.
2 X 8's on 24" centers is not a great floor for any type of tile. Way under sized.
The right way to fix this would be by working under the floor to figure out the floor is sagging and fix that.
My guess would be because of the undersized and spaced to far apart joist.
Old 12-16-2012, 06:37 PM   #3
Rewards Points: 330
thanks for your concern but sagging isn't the problem or the question
the question is " is using type S masonry the same as mixing sand and portland
to make a mud bed on galvanized lathe "
I have always dreaded taking out those old style mud beds
and have always wanted to use one to level a floor
will the "extra strength TYPE S be a problem?
Old 12-17-2012, 04:28 PM   #4
Tileguy
JazMan's Avatar
Rewards Points: 300
You're not doing masonry, so don't use it. You don't want/need the lime, makes it sticky and harder to work with as a setting bed. You want Portland/sand at about 1:5 mixed supper dry.
You can buy bagged material like this; http://www.quickrete.com/ProductLine...ToppingMix.asp It's a 1:3 mix, so add some sand to make it easier to work with.
BTW, it's "lath" not "lathe". This is a lathe, http://upload.wikimedia.org/wikipedi...-parts.svg.png
Jaz
JazMan is online now   Reply With Quote
The Following User Says Thank You to JazMan For This Useful Post:
kt82 (12-18-2012)
Old 12-18-2012, 09:23 AM   #5
Rewards Points: 330
I tried spreading some yesterday and you are correct. the lime makes it impossible to level .Thanks again
using masonry type S and lathe to level floor kt82 Tiling, ceramics, marble 0 12-16-2012 03:55 PM
Floor leveling debacle Rclancyc Flooring 5 07-31-2012 10:27 AM
Leveling an uneven bathroom floor - HELP! Teikas Dad Flooring 5 12-12-2010 09:39 AM
Cracks on my cement floor.... bcbud3 Tiling, ceramics, marble 8 11-18-2010 03:18 PM
