Unsanded Grout - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 09-05-2012, 03:19 PM   #1
Unsanded grout
I unintentionally applied unsanded grout to a bath/shower wall with mainly 3/16th grout lines. There is also a section of mosaic tile with 1/16th lines, and some lines that fall between 1/8th and 3/16th. I worked it in real well, making sure it was not too wet. After a couple of days of drying it looks fine, and was planning on at least two coats of quality grout sealer. I was trying to avoid scraping it all out and replacing with sanded. thoughts? Thanks..
Frontp is offline   Reply With Quote
Old 09-05-2012, 04:31 PM   #2
Tileguy
JazMan's Avatar
Rewards Points: 388
You said if looks fine, so leave it, seal it!
Jaz
Old 09-05-2012, 05:58 PM   #3
Pro
JetSwet's Avatar
Rewards Points: 502
Leave it your good on unsanded on walls.
JetSwet is offline   Reply With Quote
Old 09-06-2012, 01:51 PM   #4
Thank You
Thank you for the quick response...this helps a lot...
Sanded or unsanded grout for the shower surround wall tiles? nitting Tiling, ceramics, marble 10 11-30-2012 08:45 AM
Can I mix sanded and unsanded grout of the same brand and color? sukhenkoi Kitchen & Bath Remodeling 6 05-29-2011 06:27 AM
Can i apply unsanded grout over sanded grout? Philj Tiling, ceramics, marble 1 04-19-2011 07:58 PM
Tile grout... sanded or unsanded phantasm72 Flooring 5 02-26-2011 08:12 AM
Sanded or Unsanded Grout oguevarra Flooring 6 02-03-2010 03:05 PM
