#1 |
unlevel floor and diff. thickness wall tile
i have a 6'6"x 5' bath floor, level front to back but about 1/2" un-level side to side, is this to much to correct with thinset? tile is 3/8 thick. 12"x12"
Also i have a 1/4" thick glass tile accent border going between 3/8" thick wall tile, what is the best way to make the glass tile even with other tile? wall tile is 12"x12" sheets of mosaic. Another note: still can use advice on the wall tile. upon further inspection, i found if i level the floor side to side perfectly, i will have issues with the door and the transition to the hallway, the whole house tilts that way. i guess i will just bring it even a little bit and let it stay a little uneven? Last edited by bryan1282; 08-07-2011 at 01:44 PM. |
#2 |
Super Moderator
If you can live with the slope---Try for flat--that's all the maters to the tile--flat.
Leveling the floor should be done with self leveling compound--not thinset--you will end up with a wavy mess of a floor-- As to the thin accent tiles---this works for me---cut some thin plywood strips the width you need for the border and grout lines-- Set the field tiles (the big ones) and use the plywood to keep your accent tile space open and correctly spaced-- after the field tile is set and cured for 12 hours or so---remove the temporary plywood spacers--and prepare to set the thin accent tiles. First add a layer of white modified thinset and trowel that smooth in order to add some height-- allow that to cure---sand or scrape that smooth--then set the glass tiles in more white modified thinset. Check with the glass tile make if you can for an approved thinset.
New members: Adding your location to your profile helps in many ways.--M-- |
| The Following User Says Thank You to oh'mike For This Useful Post: | bryan1282 (08-08-2011) |
| Display Modes | |
