Uneven Cabinets-how Do I Tile The End Of The Backsplash? - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 10-26-2011, 09:02 PM   #1
Uneven cabinets-how do I tile the end of the backsplash?
We had new cherry cabinets installed. We changed the design and added an angled shelf on the end. We were planning to put a spacer for the base cabinets to end evenly underneath the top cabinets. Unfortunately, we found our flooring was not underneath the old cabinet peninsula and we have no extra flooring. The carpenter made adjustments but we still have the lower cabinets 3 to 4 inches shorter than the uppers. Since the phone is now there it does not bother me but I want a backsplash. The thought of an angled bullnose makes me "ill".
I thought of staggering them back and forth to have them gradually come in to meet the base end. I was planning to use 3 x 6 white matte Rittenhouse subways but this only gives me 5 rows to play with.
How would you end the backsplash?
Thank you, Golfgirl.
golfgirl is offline   Reply With Quote
Old 10-26-2011, 10:13 PM   #2
Rewards Points: 150
Maybe you could run a nice 3"-4" trim board starting just under the bottom of the top cabinet and run it down to the floor along the wall beside the back of the bottom cabinet.
Then either paint it the same as the woodwork in your kitchen, or try to match the cabinet wood. Start the backsplash on the inside of the board.
Just a thought...
NancyNGA is offline   Reply With Quote
The Following User Says Thank You to NancyNGA For This Useful Post:
golfgirl (10-27-2011)
Old 10-26-2011, 10:25 PM   #3
Military Mom of 4
Snav's Avatar
Yeah - what Nancy said.
If you need another idea: you would do wide trim (3 inches maybe) or a row of tile with under the upper cabinets that comes flush with their end (or just shy of the end - personal visual preference).
The rest of the back splash would come from the edge (or almost edge) of the lower cabinets straight up to meet with the top row (of trim or tile).
If you did this all in trim you'd have to decide how to finish it off so the edges of the tile aren't showing - they sell very narrow strips of simple trim that would work to edge it off.
At this present moment in time I am making cabinets for the kitchen - just in case you wanted to know what I'm doing when I'm not around.
Snav is offline   Reply With Quote
The Following User Says Thank You to Snav For This Useful Post:
Old 10-27-2011, 04:45 PM   #4
Interesting ideas. To put a trim board I would have to adjust my cabinet door. It is only about 1/4" from the wall. I'll try to see if I can adjust. Full overlay door.
Old 10-27-2011, 06:27 PM   #5
Military Mom of 4
Snav's Avatar
Some trims are extremely thin - 3/8" or 1/4" in thickness.
When I have issues that are quirky and need a creative solution I go to the hardware store and walk around for a while - look at different items in different departments and consider if it'll do the job.
I look at different stores, too.
The more you know about what's available to you the more creative solutions you can come up with in the future. And maybe even non-home improvement stores like craft and hobby shops, too.
golfgirl (10-28-2011)
Cabinets over tile, or tile around cabinets??? harleysilo Remodeling 10 11-02-2012 01:25 PM
tile backsplash jwc Kitchen & Bath Remodeling 2 12-02-2010 11:22 AM
Tiling / backsplash question Mark755 Kitchen & Bath Remodeling 4 02-26-2010 01:01 PM
Tile before or after cabinets MikeyP Flooring 4 03-14-2009 11:25 AM
Tile Backsplash - On Top or Behind Counter? Shandon Remodeling 10 06-10-2008 08:09 AM
