Underlayment On Subfloor - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 08-23-2009, 08:37 PM   #1
old man
underlayment on subfloor
I'm building a new house. When I put down the first layer of 3/4" T&G can I place a 1/2" cement backer board over the entire floor to get a total 1 1/8" subfloor before framing the walls? I plan to install tile throughout the house with the exception of the bed rooms which will be solid hardwood. Radiant heat will be installed below subfloor.
old man is offline   Reply With Quote
Old 08-24-2009, 02:20 PM   #2
3/4" is the minimum, I would frame the walls and everything first, then if possible, add 1/2" plywood over the 3/4" then Ditra.
That 1 1/8" makes no sense to me.
And, if you plan on stone anywhere, another set of rules apply.
R&D Tile is offline   Reply With Quote
Subfloor and Underlayment Questions JulieZ Tiling, ceramics, marble 14 06-23-2009 08:04 AM
Underlayment over diagonal subfloor rgb407 Flooring 3 08-16-2008 10:31 PM
Subfloor / underlayment question... scheenstra Flooring 7 02-21-2008 07:39 AM
Subfloor vs Underlayment indignatz Remodeling 6 12-01-2007 02:19 PM
