Underflooring For Porcelain Over Hardwood Flooring - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 05-03-2012, 05:07 PM   #1
underflooring for porcelain over hardwood flooring
I have existing kitchen that is porcelain tile over luan over hardwood flooring over 1x10 diagonal subflooring. The floor squeaks in some spots and the tiles have cracked over time.
One contractor wants to thinset hardibacker to the hardwood floor and screw it in and then thinset tile to hardibacker.
Another wants to take out luan and tile also and put a mortar bed over the hardwood floor then thinset the tile down.
I am also using the TEC power grout which is a hard grout not flexible. Please give me your feedback!
pbrn is offline   Reply With Quote
Old 05-03-2012, 05:23 PM   #2
Tileguy
JazMan's Avatar
Rewards Points: 226
Both really bad plans. You need to do more than that. Are either of these people tile setters?
Will check back later when I have time. In the mean time maybe someone will expand on my comments.
Jaz
Old 05-03-2012, 06:12 PM   #3
Rewards Points: 12,830
Nothing you have there now is a sutable subfloor or underlayment for any tile.
Tile board adds 0 floor strength.
Old 05-03-2012, 09:08 PM   #4
Tileguy
JazMan's Avatar
Rewards Points: 226
Joe is right. BTW, your present floor is a royal hack job, nothing was done right.
Don't consider anyone until they wanna;..........
remove everything until they get to the diagonal subfloor.
Repair/replace as necessary, re-fasten at every joists- 2 screws min.
Install new 1/2-5/8" underlayment grade plywood fastened only to the planks.
Install concrete backer into fresh thin set, fasten and tape per directions.
Or, install a membrane such as Ditra.
Install new tiles.
Jaz
Infested hardwood flooring (how to prevent re-infestation) diyer_12 Pest Control 4 03-18-2012 08:37 PM
First Timer - Questions About Hardwood Flooring for Stairs sunshine54 Flooring 0 10-16-2011 11:44 PM
3/4 Hardwood Flooring over sufficient subfloor? bout time Flooring 3 06-20-2011 06:15 AM
Transition of Hardwood Flooring on Stairs rkirby Flooring 1 02-02-2011 07:06 PM
Installing Hardwood Flooring on Concrete Flooring, Condo slickwilly789 Flooring 1 10-08-2010 09:53 PM
