Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Flooring > Tiling, ceramics, marble
Old 04-07-2013, 01:06 AM   #1
Tuscan leveling system
Question about this or other similar systems that might exist: I've never used them, but it seems to me that if this thing lifts a corner of a tile to level with the neighboring tile, aren't you leaving a gap below the corner of that tile? I don't think you need 100% coverage on a tile, but you also don't want an air space under the corner of a tile - the most vulnerable place. Am I missing something?
jeffnc is offline   Reply With Quote
Old 04-07-2013, 06:36 AM   #2
Super Moderator
When I use a leveling clip system, I usually use a deeper trowel--often 1/2"----the systems work very well--
I find myself using it more often with the large tiles that are currently popular.
Some lifting and back buttering may be needed if you don't have a truly flat floor---
I use the Lash system.
Boiler system not completely filling? jeffro83 HVAC 9 08-31-2012 12:56 PM
Old low voltage lighting system - switches stopped working. zepman Electrical 4 04-02-2012 01:31 AM
Need advice RE: purging air from baseboard hot water heating system mikenri HVAC 2 01-19-2011 08:17 PM
beware humidity system? Emaderton3 HVAC 5 02-11-2010 12:52 AM
Size A/C system properly 70stang HVAC 1 03-26-2006 08:22 PM
