Tumbled Stone, What Is Needed To Install - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 11-07-2011, 02:10 PM   #1
Rewards Points: 89
tumbled stone, what is needed to install
Small bathroom floor, 4 x8, I have removed all old tiles down to the old cement/concrete mud bed. The wife brought this tumbled stone home for me to install. I was expecting standard tile. Can you please tell me what else is needed or the difference in laying this and tile.
1. What do I use to lay this? Mastic, mortor, ect…
2. If I was going to lay 12” tile I would have ¼” trowel size, what do I use for this? It is on a mosaic mess backing.
3. I was going to lay it right on the old mortar bed, should I lay a ¼ hardiboard down. My fear sealing the hardi down, in the shower I had to pre-drill each screw. The floor is over a 12” thick.
Any help would be great.
chipraynor is offline   Reply With Quote
Old 11-07-2011, 02:34 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Modified thinset mortar.
A 1/4" trowel will be too big for that product. Use a 1/8" X 1/8" X 1/8" square notch.
Never install cement board over a concrete floor.
...in the shower I had to pre-drill each screw.
Have no idea what that means and not even going to go there.
Old 11-07-2011, 03:45 PM   #3
Rewards Points: 89
Have no idea what that means and not even going to go there......I had the same style of mud bed on the wall, some areas were cracked and chunks of mortar were falling off, the local tile store said to put up the hardiboard and us PL500 Adhesive and glue and screw hardi as it would be on floor. I used standard thinset with a 1/8 trowel and screwed it up every 12" into the old. ANYWAY...the shower wont ever be used.
DO i need to do anything after I lay and grout? Assuming I grout the holes in the tile?
Sealer recommendations?
white thinset, and what is modified thinset?
Old 11-07-2011, 03:59 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
"Modified thinset" is the counterpart to unmodified thinset. There are only two.
What to do where cultured stone veneer meets grass shleppy Landscaping & Lawn Care 5 09-03-2014 07:39 PM
TXV needed for new install? walkman HVAC 1 04-27-2011 12:16 AM
culture stone install question raven27 Building & Construction 4 11-02-2009 11:31 AM
Installing stone walkway bzarboni Landscaping & Lawn Care 7 06-30-2009 08:18 PM
Cultured stone issues jdrolls Building & Construction 1 06-14-2009 11:56 PM
