Tub Surround Wonderboard Question - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 10-09-2013, 02:19 AM   #1
Rewards Points: 220
Tub surround wonderboard question
Hi group my friend is a union drywall framer, he helped me with my tub surround in my condo.
I noticed the two edges from the sides to the center are not very straight. I'm sort of shocked as all the drywall he installed is perfect or close to perfect. I see he might of had issues cutting the wonderboard and or I see small bulge on the lower corner which has me worried.
My question is: should I get someone to replace the wonderboard so it is cut and screwed in straighter and cleaner or is this normal and the thinset takes care of the corners.
I'm wondering because I need to add redgard and it's quite expensive at 50.00 a gallon and don't want to use it if I have to replace the work.
dfphoto is offline   Reply With Quote
Old 10-09-2013, 03:26 AM   #2
DIY staff
Rewards Points: 7,174
See if you can post a picture----the bulge worries me--you need flat---
did he stop the board on top of the flange of did he cover it and cause a bulge?
Old 10-09-2013, 10:57 AM   #3
Rewards Points: 220
pics
Hi here are some pics sorry don't have a good overall shot
Tub surround wonderboard question-wonderboard-095.jpg   Tub surround wonderboard question-wonderboard-096.jpg   Tub surround wonderboard question-wonderboard-097.jpg   Tub surround wonderboard question-wonderboard-098.jpg
Old 10-09-2013, 10:57 AM   #4
Rewards Points: 220
The bulge is the lower corner the overlap not sure but I think a screw will push it down.
Old 10-09-2013, 01:07 PM   #5
Tileguy
JazMan's Avatar
Rewards Points: 388
That looks awful to me! Are you missing any small pets?
How about more pics using a straight edge like a 4' level as a guide?
Jaz
Old 10-09-2013, 01:14 PM   #6
Rewards Points: 220
more pics
Hi can't take pics until the end of the week, he said the tile guy will fix the corner he said wonderboard is not a perfect material to cut and the corner would be filled with thinset.
I will say no one mentioned it last week when I had couple of guys come in to look.
the walls are 98% flat and straight
Is H20 resistant sheetrock ok behind an f-glass surround? Jeffrey H Plumbing 6 11-01-2010 06:30 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
shower/tub surround prep. question mayhem69 Remodeling 7 08-03-2008 12:28 PM
Preparing to install Kerdi on bathtub surround DIY-Renovator Flooring 18 07-17-2008 10:42 AM
Tub surround shower door issues Zharkov Plumbing 14 06-30-2008 10:52 PM
