Tub Grouted Not Caulked - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 02-18-2012, 07:56 AM   #1
Tub grouted not caulked
Tub has grout between tub and tiles and in corners where tiles meet. There id no silicone caulk. Should I fix this or let be? Can I silicone caulk right over the grout or does the grout need to be removed first? I'm a DIY newbie.
gaffshot is offline   Reply With Quote
Old 02-18-2012, 08:00 AM   #2
Rewards Points: 14,312
Remove it or it's going to crack and leak, I'd use an ossilating saw with a diamond blade.
A cheap grout saw will also work. Lowes and HD will have them in the flooring tool area.
Adding clear silicone over grouted caulk for more waterproofing Louise Yarber Remodeling 4 04-23-2011 09:21 PM
Painting prep - exposed/previously caulked nails jmoe24 Painting 1 04-16-2011 09:08 AM
Should tongue and groove siding be caulked? apara Building & Construction 5 08-15-2010 06:07 PM
Transition from grouted vinyl tile to carpet MI-Roger Flooring 2 11-29-2009 12:55 PM
Moisture Barrier for Partially Below Grade Grouted CMU Wall Fire4Effect Building & Construction 4 07-06-2009 11:51 AM
