Trying To Install Self Stick Vinyl Tile On Ceiling But It Doesn't Stick - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 01-27-2012, 03:57 PM   #1
Trying to install self stick vinyl tile on ceiling but it doesn't stick
I'm trying to install self stick vinyl tile on my bathroom ceiling but it doesn't stay stuck on for long. The ceiling is painted drywall.
I've tried henrys tile primer but that doesn't seem to help much. Should I use some kind of adhesive or is it just a bad idea to be using self stick tile on the ceiling?
buggy is offline   Reply With Quote
Old 01-27-2012, 04:44 PM   #2
Tileguy
JazMan's Avatar
Rewards Points: 388
Of course it's not gonna stick. That adhesive is pressure-sensitive and only works on horizontal surfaces. Won't work on walls either. It should work if you spread a fine film of a thick-bodied mastic such as 'cove-base' adhesive. And yes, it's a bad idea regardless.
Why vinyl tile on a ceiling....had to ask.
Jaz
Old 01-27-2012, 05:50 PM   #3
It's an attic bathroom with a diagonal wall/ceiling within splash distance of the tub and self stick tile seemed like the easy solution.
Guess I'll have to figure out another solution.
Another Knucklehead Considers Laying Tile Over Vinyl Flooring tacklingherlist Flooring 14 08-26-2011 11:13 PM
Vinyl Ceiling tile installation rachellesone Building & Construction 2 08-02-2011 11:27 AM
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 06:10 PM
Peel and Stick Tile Over Existing Bathroom Ceramic Tile Floor mark2741 Flooring 2 11-03-2009 06:08 PM
Will vinyl tiles stick to this? rebekkah Flooring 1 01-12-2008 01:04 AM
