"Truing Up" A Shower Wall - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 08-02-2009, 10:01 AM   #1
"Truing up" a shower wall
I'm remodeling a master bath in our house. Since the oldest is leaving for college, I have "stolen" some space from his old room to enlarge the bath from 6'x6' to 6'x11'. The wall that is being extended is at conflux of other walls, so basically is is jammed full of studs and cripple at all kinds of different spacing.
This creates a situation where the wall is definitely not flat, and any one of the given studs is out a 1/4. I can't beat them back into place, as there is finished drywall on the other side.
I planned on putting a sheet of water resistant sheetrock on first to kinda create a average level surface. (I always called it greenboard, but now its yellow?). I was going to put the backer board over that.
No I'm having doubts about putting backer over drywall. But I can't really put the backer straight to the studs.
At this point, my best guess is 1/2 plywood, vapor barrier, backer board. I will have a pro do the tile, so my concern is to give him the right surfaces to work with.
MY QUESTION: Would it be best to move out as soon as the oldest leaves for college so he can't find out where we live? I would like feedback on the wall in case we decide to stay.
jamie howe is offline   Reply With Quote
Old 08-02-2009, 10:18 AM   #2
ccarlisle's Avatar
I think you'd best spend the time now (rather than at the time of tiling the wall) to make sure the wall is flat by sistering new 2x4s to the out-of-line old ones and make a new flat wall from that. You'd only need to sister a few of them not all, but best make sure they are true now...
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
Old 08-03-2009, 11:18 PM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
That right there is your best-bet by far.
Tags
backer board , shower , tile , wall
Can I install 12x12 porcelain tile on a shower wall or ceiling? dezigner80 Remodeling 6 09-15-2009 12:05 PM
Fixing leaking shower head...turns out pipe coming out of wall is the source plumbingboy9317 Plumbing 5 05-25-2009 01:41 PM
Temporary wall support question discojv Building & Construction 7 01-25-2009 07:23 PM
