Trowel Size Help - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 08-31-2011, 03:10 PM   #1
Rewards Points: 150
Trowel size help
What is the recommended trowel size for the 2x2 porcelain shower floor sheets that come in 12x12?
Is it v-notch 3/16"x5/32"? That is what a google search said, but I would rather hear it from someone on this board who has installed them, just to make sure.
Abs
Abs777 is offline   Reply With Quote
Old 08-31-2011, 09:18 PM   #2
Tileguy
JazMan's Avatar
Rewards Points: 232
Although you told us the tiles are 2x2 in size, you didn't mention how thick they are. That would make a difference. They could be about 3/16" porcelain or 1 cm. stone tiles. (over 3/8" thick).
However you're on the right track. 3/16x1/4" V or 3/16" square will work. Remember how the thin set is mixed and the angle you hold the trowel contributes in addition to the tile's thickness.
In general "V" trowels were used for mastic, while square were used for thin set mortar which of course is what you want for tiles.
Jaz
JazMan is online now   Reply With Quote
Skim Coat Tools? Knives, Trowel, or Magic Trowel?? Lovegasoline Building & Construction 7 08-01-2012 11:25 PM
How to cut 16 x 32 Floor Tiles & Trowel size to use atm Tiling, ceramics, marble 3 09-08-2009 08:48 PM
Building a patio cover...span and size of lumber Q's jongordo8 Building & Construction 1 08-30-2009 01:08 AM
Anyone know where to find a 5/16" x 5/16" V Notched Trowel? fjlcisco21 Flooring 5 08-12-2009 05:58 PM
Line size for Trane pomelo HVAC 1 07-15-2009 05:20 PM
