Trowel Size? - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 02-26-2010, 01:06 AM   #1
trowel size?
I recently learned that there are different trowel sizes for different jobs, was wondering which one i needed to lay 12" ceramic tiles?Thank you for your time
rsclark67 is offline   Reply With Quote
Old 02-26-2010, 09:12 PM   #2
Tileguy
JazMan's Avatar
Rewards Points: 340
Hi Clark,
I suggest you do some more research if you're going to install tiles yourself. If you want it to last anyway. I'm sure you do.
My standard trowel for 12" tiles is 1/4x3/8x1/4 square notch trowel. What are you going over and what adhesive will you be spreading with this trowel?
Jaz
Old 02-26-2010, 10:48 PM   #3
cement, and modified thinset-do I need to prime the floor?
Old 02-27-2010, 02:14 PM   #4
Tileguy
JazMan's Avatar
Rewards Points: 340
OK, so the substrate is concrete. New, old, in between, anything every on it, is it flat enough for tile, and cracks.........? You never seal concrete for thin set, it has to be absorbent and you need to check for that.
Jaz
Old 02-27-2010, 04:55 PM   #5
floor is about 12 years old, no flooring ever on it, dont know how to check for absorbancy!?Just got Kerpai ultra contact tile mortar(ok or not?)Thank you
Old 02-27-2010, 05:19 PM   #6
Tileguy
JazMan's Avatar
Rewards Points: 340
Mapei Ultra Contact is good stuff. How to check for absorbency? Try dripping some water on several spots and see it it soaks in after a few minutes or stays beaded.
Jaz
Old 02-27-2010, 07:05 PM   #7
It looks like about 70/30, I let a puddle sit for about 10 min, most absorbed some didn't
Old 02-28-2010, 11:39 AM   #8
Tileguy
JazMan's Avatar
Rewards Points: 340
Puddle? You should be testing with drops not large amounts. Hard to tell when some soaks in if there's too much water. Use a cap full or less.
Jaz
Old 02-28-2010, 01:22 PM   #9
ok, In some places the DROPS absorbed and some beaded(i put about 1 drop in 4 different areas). Oh and as for the cracks i covered them with mapeiguard, and floor is luckily all flat and level as well!
Rule of Thumb for Trowel size and Spacer size please.. K.M.G Flooring 7 02-08-2010 08:13 PM
Trowel Size? moosejohnson Tiling, ceramics, marble 4 09-26-2009 08:32 AM
How to cut 16 x 32 Floor Tiles & Trowel size to use atm Tiling, ceramics, marble 3 09-08-2009 07:48 PM
what size trowel for 4 1/4 x 4 1/4 tiles? Jim W Building & Construction 5 06-21-2009 09:27 PM
What size trowel for 20" tiles? kemerick Flooring 9 10-09-2007 09:31 PM
