Trowel Size? - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 09-25-2009, 09:11 AM   #1
Trowel Size?
Hello, just wondering size of trowel I should use? I have had conflicting answers from people and need to ask the experts for advice! I am installing 6"x12" porcelain wall tile on tub surrond using modified thin-set.
Thanks for your help!
moosejohnson is offline   Reply With Quote
Old 09-25-2009, 09:27 AM   #2
General Contractor
3/16" x 1/4" V-notch trowel.
ARI001 is offline   Reply With Quote
Old 09-26-2009, 12:07 AM   #3
Tileguy
JazMan's Avatar
Rewards Points: 226
Hi Moose & Gen cont.
Sorry contractor but you aren't even close, that trowel will not leave enough thinset for this tile. You can use a 1/4x1/4, but I would use 1/4x3/8x1/4. In any case set a few then remove them and check for coverage. You're looking for min. 85% coverage, 95% even better. Plus the cured thinset should be at least 3/32" thick.
Jaz
Old 09-26-2009, 09:30 AM   #4
Jaz
Thanks JazMan, that's what I thought!
Old 09-26-2009, 09:32 AM   #5
General Contractor
Jaz is right I recommended trowel for use with adhesive and you are using thin set. Thanks for catching Jaz. Moose the proper size trowel for tiles 8" to 12" set in thin set is actually:
1/4" x 3/8" x 1/4" U notch
My apologies for the confusion.
How to cut 16 x 32 Floor Tiles & Trowel size to use atm Tiling, ceramics, marble 3 09-08-2009 08:48 PM
Anyone know where to find a 5/16" x 5/16" V Notched Trowel? fjlcisco21 Flooring 5 08-12-2009 05:58 PM
what size trowel for 4 1/4 x 4 1/4 tiles? Jim W Building & Construction 5 06-21-2009 10:27 PM
Trowel notch size 47_47 Flooring 2 12-10-2007 12:46 PM
What size trowel for 20" tiles? kemerick Flooring 9 10-09-2007 10:31 PM
