Trouble With Tile In Shower - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 04-14-2013, 10:01 AM   #1
Trouble with tile in shower
We recently had a custom shower built. Tile was ( glued ? ) to bench area directly to hardy board. After sitting for approximately two months to dry,
the shower was eventually finished. Now two pieces have fallen off. If any
one can help, I would sure appreciate some input. The substance behind the tile is soft still.
brianclement is offline   Reply With Quote
Old 04-14-2013, 01:10 PM   #2
Tileguy
JazMan's Avatar
Rewards Points: 240
Hi Brian,
I've got bad news. That's mastic, which is not the right adhesive to use in wet applications. You'll need to remove at least part of the shower tiles especially the lower parts & horizontal. Was the floor done that way too?
Can you describe how it was all built and the materials used? Who did the work. obviously not a tile setter right?
Jaz
JazMan is online now   Reply With Quote
The Following User Says Thank You to JazMan For This Useful Post:
brianclement (04-15-2013)
Old 04-18-2013, 05:39 PM   #3
Rewards Points: 744
Who told you to wait 2 months before using the shower? I'm guessing the ripoff artist who installed the tile? Hopefully he's not long gone by now.
Seattle2k is offline   Reply With Quote
Tile shower leaking gregsenne Plumbing 9 10-02-2012 10:00 PM
Wrong sealer for shower tile. bcdemon Concrete, Stone & Masonry 0 08-29-2012 08:50 AM
Retrofit ceramic tile corner shelf in shower jgibbs Tiling, ceramics, marble 4 06-07-2012 12:29 PM
Crack in old shower tile Jeff DIY Flooring 21 01-15-2012 03:11 PM
How to tile around a Pre fab shower base geoffthemonk Building & Construction 1 11-07-2009 10:10 AM
