Trim Travertine Tile - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 04-12-2012, 11:06 AM   #1
I've got a travertine backsplash that runs from behind my stove all the way up to the microwave (over the range style). I'd like to see about removing roughly an inch from the tile, which would make the installation of our new over the range microwave a bit easier (going from a microwave that is currently 15 3/4 inches in height to a 16 1/2 inch model). Is it possible to use a grinding wheel or something similar to remove the inch or so that I need. Or would I be better off removing the tiles from the wall and reinstalling new one that are cut to the necessary height?
Thanks for your insight!
donmigga83 is offline   Reply With Quote
Old 04-14-2012, 10:02 AM   #2
Rewards Points: 236
the travertine tiles i worked with cut pretty easy. so, i would say = get a 4 1/2" angle grinder with a diamond wheel. and then carefully go at it. after cutting, a hammer and blade screwdriver to carefully knock the tiles loose.
Fix'n it is offline   Reply With Quote
Old 04-14-2012, 03:05 PM   #3
Too Short? Cut it Again!
I don't know that you even need a diamond wheel but it wouldn't hurt and you will use it for other things. A tile/masonry wheel should work as well.
That said, if you can take the tiles off and install others you will have more control over your cuts with the tiles off the wall.
Are you going to be able to get close enough to the edge with a grinding wheel with the tiles on the wall?
My Fein oscillating tool came with a blade for tile and stone but I have never tried it.
Old 04-14-2012, 07:10 PM   #4
DIY staff
Rewards Points: 7,174
The cutters for the Muli-tools would be ideal for finishing up the parts that your angle grinder can't get---travertine is very soft---Mike---
A ledger board stuck to the wall with double face foam tape will help keep the cut straight.
Hardwood Flooring install around this trim? Cmudr1 Flooring 4 01-31-2013 10:29 PM
Glass tile ruins look of travertine NewB2Homeowning Kitchen & Bath Remodeling 7 10-30-2011 07:36 AM
Trimming installed tile with tile blade in normal circular saw? jdraughn Tools 5 12-13-2009 09:07 PM
Tile with a wood trim? trick29392 Flooring 3 06-26-2008 07:19 AM
18x18 Travertine Stone Tile Install... Hages Flooring 18 10-19-2007 10:54 PM
