Travertine Tile Repair Questions - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 07-23-2012, 09:36 AM   #1
Travertine tile repair questions
I have a crack in a line of travertine tile that needs repair. How do I go about it? Where do I get what I need?
dlajohnson54 is offline   Reply With Quote
Old 07-23-2012, 09:45 AM   #2
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,074
To replace a broken tile you remove the grout surrounding it with a grout saw, break up the tile with a hammer, or hammer and chisel, then replace it using thinset. Then grout.
Matching the tile and grout may be your biggest challenge.
But before you replace the tile, you want to fix the reason for the crack, otherwise it will more than likely happen again.
A pic would help.
Also, where is the tile? Floor, wall, shower, etc.?
Solving discontinued tile issue timbo59 Flooring 14 10-03-2012 09:03 PM
Asbestos Removal, Porcelain Tile Installation jimbriam Flooring 15 01-30-2012 02:46 PM
newbie tile questions 4just1don Building & Construction 8 09-08-2011 10:58 AM
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 07:10 PM
Barker Tile Repair Cuzzy Tiling, ceramics, marble 1 01-14-2010 09:50 PM
