Travertine Over Existing Tile? - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 07-30-2009, 09:52 AM   #1
Travertine over existing tile?
Presently I have 12"X12" ceramic tile on concrete slab in the master bath. My plan is to use liquid nails to adhere 1/4" concrete backerboard to the existing tile then adhere 18"X18" 1/2" travertine tiles on the board. Does anyone see a problem with doing this? Should I use screws as well to adhere the board? Is the board necessary? or should I tile on the tile (it is in good shape - nothing loose or cracked)?
DIY Gal is offline   Reply With Quote
Old 07-30-2009, 10:46 AM   #2
RippySkippy's Avatar
Don't do it...you're asking for trouble. Remove the existing tile then install an isolation membrane like Ditra.
when it comes to breakfast, the chicken is dedicated, the pig is committed.
LMASD
RippySkippy is offline   Reply With Quote
Old 07-30-2009, 03:30 PM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
DIY Gal,
You need a lot more research before you go ahead with your plan. What you are proposing is very very wrong in several ways and with the investment you are undertaking with travertine you should first educate yourself about recommended installation practices of stone floor tile.
Don't know where you are coming up with this information but none of it is sanctioned by the industry.
Old 07-31-2009, 10:02 AM   #4
You guys are a little tough on a girl. What is wrong with my idea? The sub floor (concrete and ceramic tile) is in tact and solid - not to mention already level. The adjouning master bedroom floor has been raised by the new 3/4" wood floor and 3/4" plywood underlayment, so the overlay of backerboard and travertine will meet almost flush. I am installing a new vanity and toilet (with double wax ring) after the travertine goes in so the height will be fine on those items. The one inch increase in height will look fine as the ceilings are 10' tall.
My concern is about the actual installation of the travertine and the best way to attach the backer board. Any specific ideas?
Old 07-31-2009, 12:23 PM   #5
Well...yeah. Ok, go ahead and move forward with your plan, it will work fine. Is that better?
Your methods are no where in line with standard accepted practices...and I doubt you will find soul around here that will give you the green light...but since you're bound to do it any way...the collective "we" wish you nothing but the absolute best!
LMASD
Old 07-31-2009, 01:11 PM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Good luck and thanks for coming.
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 07:10 PM
Faux granite finish over existing tile countertop? Bulah Remodeling 1 02-15-2009 12:27 PM
Ceramic tile over existing (full mud) ceramic? rjniles Flooring 7 12-24-2008 07:12 PM
cutting existing tile rockybgood Flooring 7 12-03-2008 05:51 PM
Tile over existing tile floor? dwalls32 Remodeling 3 07-03-2007 05:19 PM
