Travertine Floor Tiles - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 05-19-2010, 06:31 PM   #1
travertine floor tiles
can travertine tiles be put on a floor on top of existing linoleum
Gino Chicorelli is offline   Reply With Quote
Old 05-21-2010, 03:45 AM   #2
more info needed for a correct answer, my gut is no since the only way it would work is if your linoleum was on concrete or glued right on 1-1/4" subfloor with the required deflection strength and you scraped the linoleum off. most of the time linoleum is stuck to particle board which is incompatible with laying tile. this would mean setting your skill saw to somewhere just a hair over the height of the particle board, cutting stripes and crowbaring it up would be required before you could get at the subfloor and determine what you're working with. if you only have a 3/4" subfloor ditra will be required if you're wanting to do this correctly.
http://www.schluter.com/6_1_ditra.aspx
will tell you which variety is required based on your joist spacing
if you have a 1-1/4" subfloor you could use cement board but the reduced labor of using ditra along with the uncoupling factor really make it the way to go on tile installs if you can swing the expense.
racebum is offline   Reply With Quote
Old 05-21-2010, 07:32 PM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
The correct quick answer is NO!
How much travertine are you talking about? (Size of area to be tiled?)
Is this on concrete or wood structure?
XXX
Bonding travertine to vinyl? Sand Building & Construction 2 12-15-2009 01:34 PM
Can I put hardwoods on top of existing travertine? jmwinke Flooring 11 11-22-2009 01:33 AM
travertine floors Keith Carlson Ceramic Flooring 4 09-29-2008 11:41 PM
Travertine Flooring & load bearing John Reiff Flooring 3 08-17-2008 08:51 AM
