Travertine On Concrete - Tiling, ceramics, marble - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-21-2013, 12:26 PM   #16
I am finally puttind down the travertine . I am attemting a no grout line install . Some of the joints are tight , others not so . What is the trick to getting the joints tight all the time ?
Az Framer is offline   Reply With Quote
Old 06-21-2013, 02:51 PM   #17
Remodeling Contractor
AZ,
Tile is designed to HAVE grout lines. The reason is that not all tile is square.
also, not EVERY tile is exactly the same thickness. There is an accepted warp page allowed in the tile industry as well.
That is why your Travertine is tight in some places and not in others. A MINIMUM
recommended grout line for ANY tile is 1/16". I doubt you will be able to have a NO Grout install that you would be happy with.
Phil,
http://www.edgestripkits.com
pgc555 is offline   Reply With Quote
How to Calculate Store Bought Concrete Coverage by Bag Size Willie T How To Guides 9 11-29-2011 01:32 PM
Repairing concrete slab in shower JohnRoss Building & Construction 0 08-08-2011 02:20 PM
New Concrete Walkway along side of house braverichard Building & Construction 0 11-03-2010 12:12 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
travertine flooring on concrete subfloor robismyname Flooring 2 09-17-2010 09:12 PM
