Travertine Backsplash - Seal Then Grout? - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 10-29-2013, 09:22 AM   #1
Rewards Points: 24
travertine backsplash - seal then grout?
I'm doing 2"x4" travertine subway tiles (the kind mounted on 1'x1' meshback) and would like to know:
(1) sanded or un-sanded grout?
(2) do I seal the tile before AND after grouting?
Gracias!
rufuscobb is offline   Reply With Quote
Old 10-30-2013, 03:48 PM   #2
Amateuralex's Avatar
Rewards Points: 266
The only factor that determines whether you should use sanded vs unsanded grout is the size of your grout spaces. 1/8" and below use unsanded.
Read the instructions on the different sealers. When I used polished travertine I sealed before and after, but i think for the stuff with the pits etc you're expected to partially fill them with grout and not seal before. Not positive.
Amateuralex is offline   Reply With Quote
Old 10-31-2013, 11:25 AM   #3
ccarlisle's Avatar
Well, OK, that's the textbook answer about sanded vs unsanded grout in a travertine backsplash application, but there is texture to consider too; I like a smooth grout there not a rough one that the sanded would give...
I am also not a fan of presealing; I say go ahead and apply, then grout with unsanded grout, then seal - if you want as it's not really necessary in such a dense stone. Plus exactly what are you sealing against anyway?
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
Sanded or unsanded grout for the shower surround wall tiles? nitting Tiling, ceramics, marble 10 11-30-2012 09:45 AM
Wait to seal if I need to remove haze on grout lines? PatrickGSR94 Tiling, ceramics, marble 2 04-07-2011 10:05 PM
Repairing missing grout in shower stall CLM Tiling, ceramics, marble 14 10-03-2010 11:08 PM
Removing grout from top of ceramic tiles markdrum1 Tiling, ceramics, marble 3 09-28-2010 10:38 AM
First tiling project. Time to grout and seal. speedster1 Tiling, ceramics, marble 5 04-26-2010 07:28 AM
