-   Tiling, ceramics, marble (http://www.diychatroom.com/f84/)
-   -   travertine backsplash - seal then grout? (http://www.diychatroom.com/f84/travertine-backsplash-seal-then-grout-189413/)
rufuscobb 10-29-2013 08:22 AM
I'm doing 2"x4" travertine subway tiles (the kind mounted on 1'x1' meshback) and would like to know:
(1) sanded or un-sanded grout?
(2) do I seal the tile before AND after grouting?
Gracias!
Amateuralex 10-30-2013 02:48 PM
1 Attachment(s)
The only factor that determines whether you should use sanded vs unsanded grout is the size of your grout spaces. 1/8" and below use unsanded.
Read the instructions on the different sealers. When I used polished travertine I sealed before and after, but i think for the stuff with the pits etc you're expected to partially fill them with grout and not seal before. Not positive.
ccarlisle 10-31-2013 10:25 AM
Well, OK, that's the textbook answer about sanded vs unsanded grout in a travertine backsplash application, but there is texture to consider too; I like a smooth grout there not a rough one that the sanded would give...
I am also not a fan of presealing; I say go ahead and apply, then grout with unsanded grout, then seal - if you want as it's not really necessary in such a dense stone. Plus exactly what are you sealing against anyway?
