Transition In Doorway From Tile To Flat Surface - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 01-19-2010, 11:39 PM   #1
Transition in doorway from tile to flat surface
Hello.
I am currently reno a small bathroom in my basement. We are installing tile onto a concrete floor. The problem is that the rest of the basement has linoleum. What do I need for a transition piece from the tile to the flat floor? This is of course the doorway.
Thanks for any help!
HuskySkull is offline   Reply With Quote
Old 01-20-2010, 06:19 AM   #2
Marble or wood threshold, available at homes stores, tiles stores, lumberyards.
Old 01-22-2010, 04:09 PM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Metal tile edging can also be used.
XXX
Old 01-24-2010, 09:47 AM   #4
What exactly do you mean from tile to flat surface?
All your basement is concrete and one portion has linoleum on it and the bathroom floor has no floor coverings? And now you want to add tile which will make the bathroom floor a touch higher than the linoleum floor?
If that is the case- then you have many options from wood , marble, granite - if you use these materials I suggest a bevelled edge to make for a smoother transition.
You can also go with a metal of plastic profile. Type in Schluter-reno-u to get an image to what is being described.
Be sure to look over your concrete floor, if it has one or many cracks, I would be careful how I install the tiles over them. You need to isolate the cracks. One good way is to install a floor membrane. You can look that up on the same site and if you do find cracks on the floor, you can ask me for more details. Personally, I would always use such a membrane on a small concrete floor prior to installation.
MarbleMaestro is offline   Reply With Quote
Old 01-27-2010, 08:37 PM   #5
what kind of tile?
just tile is offline   Reply With Quote
Improving a bad tile to drywall transition navi_jen Drywall & Plaster 6 11-27-2013 09:56 AM
Transition from Hardwood to Marble Tile (1/4" lip)??? tigerbalm2424 Flooring 5 11-17-2009 07:18 AM
Tile Cutter vs. Tile Saw jamiedolan Flooring 8 11-09-2008 03:17 AM
Redo transition from carpet to tile bkeech Flooring 1 11-08-2008 07:02 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
